Author Topic: Installing new head/cyl gaskets- best way to get old gaskets off??  (Read 1498 times)
Offline kippstakes
Tore my engine down and the old gaskets are stuck on like concrete. Used a razor to get most of the bulk off but there is still a substantial amount of residue left on the flanges.
Any tips on how to get that stuff off? Considering a gasket removal compound, but which works best?
Thank you
Strength is just an accident arising from the weakness of others.
-J. Conrad
Offline cheftuskey121
  • Super Newbie
Re: Installing new head/cyl gaskets- best way to get old gaskets off??
« Reply #1 on: January 11, 2014, 11:24:32 PM »
I've heard beer is the best (only) tool to help get the gaskets off ;)
« Reply #2 on: January 12, 2014, 07:33:12 AM »
I recently used Zip Strip heavy duty paint remover.....let it set for a few hours and it did a great job.
« Reply #3 on: January 12, 2014, 09:24:13 AM »
Permatex gasket remover spray, and a plastic scraper.
Offline kippstakes
« Reply #4 on: January 12, 2014, 10:08:12 AM »
Thank you for the suggestions, think I have a good starting point.
-J. Conrad
Offline bjbuchanan
« Reply #5 on: January 13, 2014, 11:25:03 AM »
I used an xacto knife with the blade that is more like a scraper, not the scalpel or regular knife ones they come with.
Flexible thin blade really gets under there easily and gives you a lot of control. Easier clean up too. Doesn't take that much time really. I cheated and put xylene on the old gaskets to wet them up
fendersrule
« Reply #6 on: January 13, 2014, 11:35:00 AM »
I've used a mix of all solutions mentioned and removing gasket material is still no walk in the park. Beer + patience.
Offline Lostboy Steve
« Reply #7 on: January 13, 2014, 12:05:42 PM »
My buddy uses these. http://3mcollision.com/how-to/mechanical-department/engine-repair/gasket-removal-and-surface-conditioning/scotch-brite-radial-bristle-brushes/scotch-brite-roloc-bristle-disc-07524-2-inch-coarse.html He swears by them for all metal surfaces. He's a BMW automobile tech and thats what his dealership supplies him with.
1968 Honda Z50
1977 Honda CB550K
2018 Indian Scout
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #8 on: January 14, 2014, 08:23:17 AM »
that would probably work. There are also plastic brushes that fit into a normal drill motor tnhat can be found at any Home depot. They used to be called Nyloc but I don't know the brand name anymore. Plastic won't gouge the deck surface but it works great for stubborn paint and gasket material.
Similar to these:
http://www.mscdirect.com/industrialtools/nylon-wire-wheel-brushes.html
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline edwardmorris
  • Youngish
« Reply #9 on: January 14, 2014, 08:28:57 AM »
I did this few days ago, most of the rough parts comes off with gentle scraping and for the tough stuff, I used acetone and a gift card. For the final baked in bits, I wet sanded with 1000 grit paper wetting with acetone itself. Worked wonders, there are some before and after pix in my build thread.
Offline Tugboat
  • Puppet
    • PseudoMoto
« Reply #10 on: January 15, 2014, 10:26:56 AM »
+1 on the 3M Roloc discs. Those things are great! But as has been said: heat + patience.
Offline KrautKoffin
« Reply #11 on: January 15, 2014, 11:03:06 AM »
Did the gift card have any money on it still?
74 cb550
I now have Beastie Boys "Sabotage" stuck in my head after seeing your avatar.
« Reply #12 on: January 15, 2014, 12:41:20 PM »
this must be the only place where you'll get beer and razor blades as a suggestion, and not be considered 10-96  ;D
Offline kippstakes
« Reply #13 on: January 15, 2014, 07:04:51 PM »
thanks for the replies. guess i will just take a page from all your books and attack it from multiple fronts. funny that getting a gasket off would end up being the hardest damn part of rebuilding my engine. then again, i don't haven't started putting it back together yet..
thanks again.
-J. Conrad
