When you do a chop, make sure your plugs are clean to start with. I would say to also do a chop at 3 different rpm ranges.
Start with idle or just above idle, then move on to mid-range about 4000 rpm or so, then do one around 7000 rpm.
My reasoning is this, Each speed is using different jets. The idle will show if your low speed is lean or rich.
The mid-range shows the mix between the 2. Going at 7000 or above and you are on the mains only.
From what I have read by Two Tired, this is a commonly held misconception. RPMS are not what determines what jets are being used, it is throttle position. People say to mark your throttle at 1/4 throttle, 1/2 throttle, and 3/4 throttle, and THAT is how to do a plug chop.
While RPMs are loosely tied to throttle position, they are not in direct linkage.
Chops are based on throttle opening measurements, not RPMs.
Not trying to shoot you down eldar, just bringing up a differing opinion I read here. (I am by no means any type of master, and have not yet done a plug chop on my bike) That said, it is just based on what I have read, not actual experience.
doing it this way can tell you more than just a WOT chop ever could.
I guess I would recommend doing a chop at idle or 1/4 throttle., 1/2 throttle, and either 3/4 or WOT (wide open throttle) instead of idle, 4ooo and 7ooo RPM. Each speed is not using different jets, each throttle position uses different jets,
If we take the throttle position vs jets used graph as true.
Doing multiple THROTTLE position chops WILL tell you more about what jets are too rich vs too lean.
Peace,
jugghead
