Author Topic: 3 ohm vs. 5 ohm coils with dyna S  (Read 4412 times)
Offline IBleedHondaRed
    • OEM Parts diagrams from my shop
« on: February 04, 2014, 01:41:21 PM »
looking for advantages and disadvantages and experiences to the different resistance options for both a cb550f and a cb350f when used in conjunction with a Dyna S electronic ignition system. im reading conflicting things about recommendations for applications. im planning on doing updated electronic systems on both bikes and want to make sure im spending wisely
OEM DIAGRAMS http://www.shopstarcitypowersports.com/OEMpartfinder.htm
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
1989 Hawk GT 647 (Adventure)
1989 Hawk GT 696 (Barely street legal track bike)
2007 XT225
2008 650 Gladius
2012 CB1000R
2012 VT750 Phantom   SER #000105
2013 F6B Goldwing      SER #000082
2013 KTM 300 XC-W
2014 CTX 700             SER #000043
Offline dragracer
  • CB750F Dragbike
Re: 3 ohm vs. 5 ohm coils with dyna S
« Reply #1 on: February 04, 2014, 03:40:12 PM »
I'm sure you'll need to use the 3 ohm coils. Typically the lower resistance coils are used in conjunction with aftermarket ignition systems  like msd or dyna boxes
Offline joe p
« Reply #2 on: February 05, 2014, 03:47:51 AM »
I read somewhere that 3 ohm coils could be used on street bike but 5 ohm coils get to hot on street bike. I never ran 5 ohm coils on the street so I do not know if this is right.
« Reply #3 on: February 05, 2014, 06:32:42 AM »
the paperwork that came in dads box said to use his dyna s with 3 ohm coils. it also stated that the 5 ohm coils were for points setups. im seeing on here that many folks disagree. which sucks because we ordered dad a set of 3 ohm coils for his 73 cb500.
i want to know why people disagree
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
Offline joe p
« Reply #4 on: February 05, 2014, 07:59:06 AM »
I ran 3 Ohm coils(green) with my Dyna S on my CB-750 for years without a problem.
« Last Edit: February 05, 2014, 08:07:16 AM by joe p »
Offline locomonza
« Reply #5 on: February 05, 2014, 09:45:09 AM »
Same here, no problem for years, 3 ohms Dyna s.
Offline Kemp
« Reply #6 on: February 05, 2014, 12:09:30 PM »
I've talked to Dyna about the coil situation as the charging systems are so marginal on the CB350/400 and CB500/550 Fours. Dyna recommends the black 5 ohm coils for these bikes. Hondaman even offers a 2 ohm resister kit to use on the green 3 Ohm Dyna coils to reduce the current draw to that of the 5 ohm. The Pamco Ignition sounds like a better bet as its electronic system (ignition and coils) draws almost the same current as stock. The Dyna Ignition itself and Dyna coils themselves draw one heck of a lot more! Here (below) is a note I got from Pete at Pamco about using their system on the Honda CB400F
The stock points setup on the CB400F uses a 180 degree dwell angle (50% duty
cycle) with 5 Ohm coils, so the average current flow is 13/5 = 2.6 Amps X 50% duty cycle = 1.3 Amps. The Ultimate coil is 2.5 Ohms, but the dwell angle is 120 degrees for the PAMCO, or 33% duty cycle, so the average current is 12/2.5 = 4.8 Amps X 33% = 1.58 Amps. That's just 1.58-1.3 = 0.28 Amps more. Not a factor for the charging system. (The electronics in the PAMCO use less than 10ma, so not a factor)
« Reply #7 on: February 05, 2014, 02:59:03 PM »
DYNA finally messaged me back. they confirmed to use the 5 ohm coils on both the 350f and 500k
1971 CB500K0
1973 CB350F (x2)
1973 CB350G
1973 CB500K2
1977 CB550F2
2007 XT225
2008 650 Gladius
2012 CB1000R
2013 KTM 300 XC-W
