Author Topic: 76 CB550 engine parts different?  (Read 896 times)
Offline Doggie
  • CB550F, CB650c, CB550k, Cb750K
« on: February 09, 2014, 09:53:38 PM »
    While taking apart a CB550 engine, I noticed that the Cover, Cylinder head, was different than on my other engine. Both have (4) bolts in the middle, but the other has (4) more bolts to the outside of the middle (4) that don't seem to do anything.
     Is this a newer model cover? Which one is better? And what is the reason for the change?
                                                 Doug
Offline jonda500
Re: 76 CB550 engine parts different?
« Reply #1 on: February 09, 2014, 09:56:24 PM »
I had to ask this question too!- they are in fact cotter pins that the later models had to stop the rocker shafts turning.
A starter clutch thread:
Offline Doggie
« Reply #2 on: February 09, 2014, 10:07:05 PM »
So this is a newer and better model?
                                               Doug
Offline jonda500
« Reply #3 on: February 09, 2014, 10:44:06 PM »
                                               Doug
I believe that is correct. Although I haven't seen any problems with the older design I'm sure honda changed it for a reason!
Offline DustyRags
  • I'm not skilled, I'm just a
  • Just try it and see what happens
« Reply #4 on: February 10, 2014, 07:35:56 AM »
The steel rocker shafts would turn in the aluminum head, and gradually elongate their holes. That led to loose rockers that couldn't be fixed. By pinning the shafts, Honda forced the steel rockers to turn on the steel shafts, and the whole thing lasts much longer.
1976 CB550K- sold
2005 Kawasaki Vulcan 500- sold
2000 CB750 Nighthawk - sold
1975 XL350 - crashed
2004 Suzuki Vstrom 650 - sold
Offline Doggie
« Reply #5 on: February 10, 2014, 11:33:42 AM »
So if I wanted to put the best one on, I would use the newer version. Cool... Thanks for all the input. I knew you guys would know, lots of knowledge in this forum.
                                                             Doug
