Author Topic: DOHC coils- which side is "+"?  (Read 3345 times)
Offline greddm
    • CB750 Cafe Build
« on: February 15, 2014, 04:56:52 PM »
I've got a set of used DOHC (not sure the year) coils to use with my dyna-s ignition. I'm just not sure how I tell which spade goes to the ignition and which goes to power? Pic below.
1977 CB750
Offline bjbuchanan
Re: DOHC coils- which side is "+"?
« Reply #1 on: February 15, 2014, 04:59:05 PM »
They don't have a positive or negative, that's why they aren't marked. These types of coils don't work like that
Just hook them up either way, making sure to have blue/yellow going to the correct set of points.
If they are DOHC coils they are gonna only be 3 ohm, use more current but don't get more oomph really. Just a thought
Offline greddm
    • CB750 Cafe Build
« Reply #2 on: February 15, 2014, 05:02:39 PM »
Thanks. I was told they were 5ohm. 3 will still work though right? I'm using them because I got them with a bunch of other parts, so trying to save $$$.
1977 CB750
« Reply #3 on: February 15, 2014, 07:03:49 PM »
check them with a multimeter anyway?
Offline thirsty 1
« Last Edit: February 15, 2014, 07:23:17 PM by thirsty 1 »
Online HondaMan
« Reply #5 on: February 15, 2014, 07:23:56 PM »
1977 CB750
I'd sure recommend checking them with a meter. I don't think any DOHC coils were even 3 ohms, most were even less than that. This will toast your Dyna.
Offline greddm
    • CB750 Cafe Build
« Reply #6 on: February 15, 2014, 07:25:47 PM »
Do I connect the meter to the spades or the plug side?
1977 CB750
« Reply #7 on: February 15, 2014, 07:31:48 PM »
the spades to determine the resistance ohms,the less resistance is like a higher wattage light bulb,itll pull more current,itll load what ever is powering it heavier.
« Last Edit: February 15, 2014, 07:33:22 PM by dave500 »
Offline greddm
    • CB750 Cafe Build
« Reply #8 on: February 15, 2014, 07:37:54 PM »
So does this mean I've got 3ohm coils?
1977 CB750
« Reply #9 on: February 15, 2014, 07:40:15 PM »
your meters internal battery is down,thats the "BAT"icon in the dispaly upper left,replace it first then recheck,a low meter battery can make them speak with forked tongue!
Offline greddm
    • CB750 Cafe Build
« Reply #10 on: February 15, 2014, 07:41:04 PM »
Ha ha, we'll do
1977 CB750
Online HondaMan
« Reply #11 on: February 15, 2014, 07:57:48 PM »
Also: digital meters have their own offset resistance in low Ohms range. So, after the new battery is in, touch those probes together and take the probes-only reading (likely around 0.5 ohm or so), and then SUBTRACT that number from your coil reading. You probably have 2.5 ohm coils there, which is typical of the DOHC systems using CDI ignition boxes. These are not a good coil for the SOHC4 bikes.
Offline bjbuchanan
« Reply #12 on: February 15, 2014, 07:58:25 PM »
you catch the oddest stuff dave
Offline greddm
    • CB750 Cafe Build
« Reply #13 on: February 15, 2014, 08:01:40 PM »
Last time I buy a box of random crap from someone with only their word on what it is! Good news is that they were practically free. So for replacements should I go with 3 or 5 ohm dyna coils?
1977 CB750
« Reply #14 on: February 15, 2014, 08:05:39 PM »
its attention to detail bjbuch,use what ever coils are recommended for the dyna system you have greddm,good reminder aswell hondaman,we often forget that!
Offline greddm
    • CB750 Cafe Build
« Reply #16 on: February 15, 2014, 08:12:20 PM »
Thanks thirsty 1, I think I'll get dynas
1977 CB750
« Reply #17 on: February 15, 2014, 08:14:08 PM »
Thanks thirsty 1,i think ill get a beer?
« Last Edit: February 15, 2014, 08:16:29 PM by dave500 »
Offline thirsty 1
« Reply #18 on: February 15, 2014, 08:21:25 PM »
Cheers Mate!! Have a Tooheys Old for me.. :D
« Reply #19 on: February 15, 2014, 08:24:59 PM »
ah tooheys old,two headaches in every bottle?
Offline thirsty 1
« Reply #20 on: February 15, 2014, 08:29:18 PM »
at the least haha or maybe a Coopers then ...
« Reply #21 on: February 15, 2014, 10:22:33 PM »
coopers is fermented mud.
« Reply #22 on: February 15, 2014, 11:42:59 PM »
Wouldn't matter if it was solid concrete Dave, if thats all you had you'd drink it.... ;D ;)
« Reply #23 on: February 16, 2014, 12:27:28 AM »
BUURRPP!
« Reply #24 on: February 16, 2014, 12:53:44 AM »
BUURRPP!
I'll take that as a "yes".... ;D
