Author Topic: Found a milky white substance on my dipstick  (Read 4320 times)
Offline Ford40
« on: February 20, 2014, 10:51:19 AM »
After I got back from a trip to lunch I pulled the dipstick out to check the oil level and found some foamy white milky liquid on the cap part of the dipstick and there was also some smoke coming out of the oil tank. Does anybody know what could be causing this. Bike is a 1976 CB750.
Offline Jeremy C.
Re: Found a milky white substance on my dipstick
« Reply #1 on: February 20, 2014, 11:11:55 AM »
It sounds like condensation in the oil tank. Do you live in a humid area or one prone to rapid temp change? I'd spend the $25 and change the oil.
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: February 20, 2014, 11:16:45 AM »
You will always get that if you only ride short distances. The bike doesn't reach full operating temperature and condensation forms.
Take it for a longer run every week.
Wobbly
« Reply #3 on: February 20, 2014, 12:31:59 PM »
Not to worry. Happens to me all the time--especially in the morning when I wake up.  ;D
Offline Duanob
  • Bold Timer
  • Gotcha!
« Reply #4 on: February 20, 2014, 12:48:52 PM »
better see a doctor  :o
Is the bike stored outside in a wet climate? If this were a water cooled vehicle you might worry a bit but an air cooled bike nothing to worry about, just go ride it long and hard to warm the engine and dry it out.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
  • 1977 CB550F2
« Reply #5 on: February 20, 2014, 12:52:03 PM »
Or a lady of the night.
« Reply #6 on: February 20, 2014, 01:12:35 PM »
Penicillin and a looooong freeway ride usually will clear that up  ;D
Offline skidooextreme
« Reply #7 on: February 20, 2014, 01:20:53 PM »
No need to change the oil. Its just moisture, take her for a good ride!
Offline 750K
« Reply #8 on: February 20, 2014, 03:14:26 PM »
I always pull the dipstick out quick and slip it back in before a good hard ride :)
77 Cb750, 78 Kz1000
Offline 74750k4
« Reply #9 on: February 20, 2014, 03:47:29 PM »
She's just showing her affection, and wants you to take her out.
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
« Reply #10 on: February 20, 2014, 04:27:08 PM »
^^This. This is the risk of starting a bike for a few minutes in the winter and shutting it down before it's truly good and warmed up. There will always be some degree of condensation and it needs to burn off. Take it out and play with it for longer!
I have a motorcycle problem.
Offline reddyvv
« Reply #11 on: February 20, 2014, 04:42:26 PM »
Looks like someone else took it for a ride before you got to it!!  ;D ;D
But in all seriousness that looks like some serious moisture contamination of the oil. You will need a good long ride to get all that moisture to evaporate out of the oil.
On a side note, a few days ago I elected to do a little winter maintenance on my 550 and took the clutch cover off. I was shocked at the amount of condensation in there. There were beads of moisture everywhere like someone had splashed water inside the engine. Start it up and all that water gets mixed in with the oil.
« Last Edit: February 20, 2014, 04:49:51 PM by reddyvv »
« Reply #12 on: February 20, 2014, 08:07:08 PM »
PENICILLIN STAT!
Offline 750K
« Reply #13 on: February 20, 2014, 09:46:57 PM »
Taste it, if its salty your in trouble...
77 Cb750, 78 Kz1000
Black 750K8
« Reply #14 on: February 21, 2014, 06:52:12 AM »
I hope you are speaking from your own personal experience. :o :o :o
Offline Cqyqte
« Reply #15 on: February 21, 2014, 07:18:21 AM »
I'd see your Doctor and stay away from your girlfriend until it clears up!
Offline 750K
« Reply #16 on: February 21, 2014, 08:31:38 AM »
So I've heard from old girlfriends ;)
77 Cb750, 78 Kz1000
« Reply #17 on: February 21, 2014, 10:14:08 AM »
I am so glad you are talking about the bike..
Post your location in the profile..easier to give an answer...ie, if you were in AK, I could say you got a few more months of that problem..
Offline Ford40
« Reply #18 on: February 21, 2014, 10:24:40 AM »
Thanks for the replies. I'm located in South Carolina and it has been kinda rainy lately so I guess thats my problem. Does anybody know where to get a new rubber for the dipstick as mine is pretty crusty.
Offline bjatwood
  • I never claimed to be an
  • 1973 CB750-K3
    • Minbikers Proboards
« Reply #19 on: February 21, 2014, 10:58:46 AM »
Most drug stores have packages of new rubbers for dipsticks on their shelves. Make sure you clean the dipstick up well as that crust can become uncomfortable.... ;)
Brian
#24193
I believe that the Finest things are the most thoughtfully made, not the most expensive!
http://minibikers.proboards.com/
Markcb750
« Reply #20 on: February 21, 2014, 11:16:35 AM »
Santorum  ::)
Just because it had to be said.
Black 750K8
« Reply #21 on: February 21, 2014, 11:53:26 AM »
Do you have a K or F?
Looks like #2
http://www.cmsnl.com/honda-cb750k-750-four-k-1976-usa_model494/partslist/F++14.html#results
DSS has the stick complete. They also have a dip stick with a temp gauge. Scroll down half way down.
http://www.davidsilverspares.com/CB750K-FOUR-1976-USA/
Offline cheftuskey121
  • Super Newbie
« Reply #22 on: February 21, 2014, 03:10:58 PM »
I am in savannah ga and I get the foam too if I don't ride for more than 30 minutes...lots of humidity here.  I try not to ever do that. Also I am using that dip stick with temp gauge and it's nice. A little tight of a fit but it's nice to have a general idea of my oil temp.
Offline Damfino
« Reply #23 on: February 21, 2014, 06:06:36 PM »
I hate when that happens, as for the 'crusty' part, you're on your own!
Your Message Here!
1976 CB 750
2014 CB 1100DLX
Charles Manson
