Author Topic: Blue pipes on 400F  (Read 1248 times)
Offline RichM
Blue pipes on 400F
« on: February 24, 2014, 04:06:18 PM »
Hi Guys. I'm new to the forum and am reliving a bit of my childhood by purchasing two 1975 CB400F's. One is a 2,100 mile "display piece". My concern however is the blued pipes. That would seem to indicate a lean burn situation. Can anyone point me in the right direction- ie. don't ride it until you.....
The second 400 I purchased is a 20K mile "fixer upper" that I'm sure I'll be on the forum about.
Thank you in advance for any help you can provide!
1981 Honda Goldwing
1999 Honda Valkyrie
1975 Honda CB400F (X3)
Offline brooze72
Re: Blue pipes on 400F
« Reply #1 on: February 24, 2014, 05:20:04 PM »
Welcome Rich.  Yes, it can be an indication of a lean condition.  A 3k tune up & carb sync would probably be advised, check the plugs & carbs (for jet size, clip position, etc) vs stock.  Are the headers/pipes/muffs  original?  Honda used mostly double wall headers, so it's not as common to blue as easily as some aftermarket stuff (or golden like stainless does) or like Brit bikes do.
1972 CB500K1 - restored rider
1981 CB650C - new project
Offline LesterPiglet
  • 1977 CB550F2
« Reply #2 on: February 24, 2014, 05:24:22 PM »
Once they are blue they stay blue.   :(
Offline RichM
« Reply #3 on: February 25, 2014, 04:03:39 AM »
Thanks for the reply guys. This bike is supposed to be bone stock (and it looks to be- even the tires). I was advised to maybe try some Yamalube carb cleaner in case the jets have some clogging. Suggestions? Also, I understand that there's no way to improve the blue color short of a re-chrome. That's a shame since the bike is otherwise perfect.
1981 Honda Goldwing
1999 Honda Valkyrie
Offline Sami1987
  • Rob.leedy@gmail.com
« Reply #4 on: February 25, 2014, 06:49:20 AM »
Blue-away works very well on
discolored pipes. I have used
it for years.
  • 1977 CB550F2
« Reply #5 on: February 25, 2014, 07:25:49 AM »
it for years.
Do you have a link?
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #6 on: February 25, 2014, 12:15:35 PM »
Blue-away is sold by Frost restoration in the uk
http://www.frost.co.uk/blue-away-metal-cleaner.html
The Harley guys apparently swear by Blue-Job
http://www.blue-job.com/
Build threads:
1977 CB750 F2
1958 Norton Model 99
  • 1977 CB550F2
« Reply #7 on: February 25, 2014, 12:27:15 PM »
Thanks, I'll have to give it a go.
  • 1977 CB550F2
« Reply #8 on: February 25, 2014, 12:47:53 PM »
Bloody expensive.   :-\
Offline martin99
  • UK Based, Non-
« Reply #9 on: February 25, 2014, 01:18:47 PM »
Yeah, that's why my bikes still have blue pipes!
Build threads:
1977 CB750 F2
Offline fmctm1sw
« Reply #10 on: February 25, 2014, 05:14:36 PM »
As mentioned, there's some stuff out there.  Here's my flitz thread: http://forums.sohc4.net/index.php?topic=131549.msg1468098#msg1468098  This stuff works wonders on yellow headlights too.  You should see the headlights on my prius ....
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
