Author Topic: 550 lower steering bearing race OD.  (Read 935 times)
Offline Dimitri13
  • 1974 CB550K
« on: February 27, 2014, 10:15:24 PM »
Need to know the OD of it so I can get a socket to drive the race in. I don't have access to it right now otherwise I'd measure it myself.
Re: 550 lower steering bearing race OD.
« Reply #1 on: February 28, 2014, 05:16:30 AM »
50mm.
Black 750K8
« Reply #2 on: February 28, 2014, 06:35:48 AM »
So if you don't have a metric socket that would be a 1-7/8th socket or maybe a 1-15/16th?
Offline Dimitri13
  • 1974 CB550K
« Reply #3 on: February 28, 2014, 11:30:39 AM »
50mm doesn't sound right. I was driving it in with a 1-1/2" socket, but it was too big to fit in the headstock. 36mm was too small.
« Reply #4 on: February 28, 2014, 12:00:56 PM »
How about 49.99mm? This is the outer race OD for the lower steering head bearing.
Offline Dimitri13
  • 1974 CB550K
« Reply #5 on: February 28, 2014, 03:05:47 PM »
Are we talking about the same thing?
Tapered bearing if that makes a difference.
Black 750K8
« Reply #6 on: February 28, 2014, 04:56:58 PM »
Look up your bike here and post back with what you are talking about.
http://www.cmsnl.com/honda-cb-four_model7148/
Offline jonda500
« Reply #7 on: February 28, 2014, 05:08:10 PM »
50mm.
+1  just went out to the shed, measured(I have a frame with no bearing cone in it), it is definately 50mm!
A starter clutch thread:
Offline Dimitri13
  • 1974 CB550K
« Reply #8 on: February 28, 2014, 07:07:09 PM »
Nevermind, I'm a tard and forgot how to tool. The socket was 1-1/2", but the OD of that socket is 52mm. I didn't measure the OD of the 36mm socket, but I'll try renting a slightly bigger one, making sure to measure the OD at the store.
