Author Topic: Re: 650 overbore/550 engine hybrid underway...final stages  (Read 81290 times)
Offline paulages
  • 1976 cb735
    • DOOMTOWN RIDERS P.R.M.C.
Re: 650 overbore/550 engine hybrid underway...piston clearance specs
« Reply #150 on: September 25, 2007, 11:53:45 AM »
Sounds good Paul, it's great to have all that measuring behind you. Remember to be safe, just double check clearances when you time the cam and have the degree wheel in place. At 10 degrees or so before & after TDC gingerly push the valve down until it just contacts the piston and get the true reading from the dial indicator.
I'm sure you're all set to do this anyway, but the rest of us feel a part of this process too! Ha
thanks. believe me, i'm triple checking everything. wouldn't the clay method indicate the clearances at the closest point the valves are to the piston? i just followed dan's instructions: put clay on top of the piston, oil the head side, bolt the engine up, and run it through a few times. the valves left clear imprints, which i dissected down the middle to measure. i can't remember what the stock 650 lift is, but i imagine .098+ clearance will give me plenty of room even if i add left and duration. ideally, i'd have wanted to clay it with the cam i'll be using, but alas i don't have that yet.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1976 CB550 (590cc) road racer
1973 CB750K3
1972 NORTON Commando Combat
1996 KLX650 R
Offline mlinder
  • "Kitten Puncher"
  • Stop Global Tilting now!
    • Moto Northwest
« Reply #151 on: September 25, 2007, 12:20:51 PM »
Did you just say 'alas', Paul?
Oh yeah, wheres the pics?
By the way, theres a "classic japanese motorcycle' ride this Saturday. Interested?
« Last Edit: September 25, 2007, 12:27:59 PM by mlinder »
No.
Offline paulages
  • 1976 cb735
« Reply #152 on: September 25, 2007, 12:29:13 PM »
i'll get em up, and yes i probably am.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #153 on: September 25, 2007, 12:43:34 PM »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline Pinhead
  • 1979 CB652-ST
« Reply #154 on: September 25, 2007, 04:29:37 PM »
Is the .098" clearance with the stock pistons and stock cam?
Doug
GM HEI Ignition Conversion
Quote from: TwoTired
:D
Offline paulages
  • 1976 cb735
« Reply #155 on: September 25, 2007, 06:57:33 PM »
stock cam, yes. stock pistons, no, or i wouldn't have bothered checking for clearances. the pistons are intended for a 750, but have been machined to fit the 650 head.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #156 on: November 02, 2007, 01:09:42 PM »
crank, pistons, rods and stator are balanced. the crank was almost perfect stock (not sure if that's always true, but might be nice to know for some of you 650 people). the I.D. of the 550 stator has been bored out to fit the 650 crank.
just have to weld up the oiler for the chains in the bottom case, drill and tap for the oil lines, and then build it up!
i have an idea for polishing the trans gear teeth a la hondaman's performance tips. i'm going to use some extra cases i have to mount the gears, then mount the engine into a frame, which will be upside down. with the oil pan removed, i'll be able to access all the gears for applying the lapping compound, and i'll use an electric motor to belt drive the gears via the clutch hub. this oughta work a little faster than doing it by hand.  ::) i'll post pictures once i get the contraption setup.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Online MRieck
« Reply #157 on: November 02, 2007, 01:25:56 PM »
Jerry Branch basically did the same thing you are thinking of Paul with Harley race transmissions years and years ago. Motor driven sets with compound. As a side note...I'm very much looking forward to the completion of your project. I admire your confidence and mechanical abilities.
« Last Edit: November 02, 2007, 01:31:42 PM by MRieck »
Offline paulages
  • 1976 cb735
« Reply #158 on: November 02, 2007, 01:30:04 PM »
that's good to hear. i have to admit, i'm a bit nervous about getting valve lapping compound anywhere near the trans bearings, but i guess i'll just use old ones in case it gets messy at all. from what i remember concerning gear lash from my transmissions classes years ago, doing this seems a bit counter-intuitive, but i guess i'll trust the masters here.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #159 on: November 02, 2007, 01:31:43 PM »
by the way mike, do you think i am missing anything important here (aside from not having some better rods)? should i balance the clutch hub too?
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Online MRieck
« Reply #160 on: November 02, 2007, 01:35:17 PM »
It's not a bad idea at all as long as the balance shop has a mandrel to hold the basket. They should.There are basically 2 types of imbalance which can effect the basket. One causes an up and movement. The other causes a wobble effect. It's nice to eliminate those forces.
Online MRieck
« Reply #161 on: November 02, 2007, 03:55:16 PM »
Branch fabricated a "box" to hold the trans shafts. You don't want to turn the shafts to fast. Very slow is best.  Obviously small pulley/shaft on the drive side and big one one the trans shaft. After 8 or 10 hours....perfection. Use real fine Clover. You don't need much either seeing how long you will be spinning it
« Last Edit: November 02, 2007, 06:23:18 PM by MRieck »
Offline paulages
  • 1976 cb735
« Reply #162 on: November 02, 2007, 08:04:06 PM »
well, i built the contraption tonight, but it definitely spins too fast. i need to figure out a way to slow it down considerably. i'll take pictures tomorrow. i had billdramp and another friend (and mlinder for a few minutes) down there scratching our heads figuring out how to mount the electric motor so that there would be enough tension on the belt. turned it on, and it spins great...but really fast. i'll try to fashion a rheostat tomorrow to control the voltage to the motor.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #163 on: November 02, 2007, 09:28:11 PM »
i also forgot to mention that dan took another .030" off of the shoulder of the piston achieve a total .050" piston to head clearance. i'll post a summary of all mods once it's done, as i just read back through this thread and found it quite confusing.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #164 on: November 02, 2007, 10:22:09 PM »
told ya, lmfao.
Anyway, like I said, just put that larger pully wheel on it. It's like, twice as big. Will slow it down by half.
No.
Offline paulages
  • 1976 cb735
« Reply #165 on: November 02, 2007, 11:57:05 PM »
told ya, lmfao.
 ::) ::) sorry, mark... i'll try to listen to you more when designing my mad scientist gadgets. i knew it would be too fast, but don't think the solution is a simple as the pulley. i'll try a simple rheostat, and see if i can get it down to a decent crawl.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline DarkRider
« Reply #166 on: November 03, 2007, 07:09:57 AM »
ok..just wondering...what did the final displacement wind up being on this beast?
'84 Chevy C10
'73 MGB Roadster
'69 Ford F250
Quote from: heffay
Offline mlinder
  • "Kitten Puncher"
    • Moto Northwest
« Reply #167 on: November 03, 2007, 08:02:19 AM »
told ya, lmfao.
lmfao.
Don't listen to me.
I woke up this morning saying to myself "Jesus, Mark, are you effing dumb? A larger pulley will make it go faster you damned numbskull."
It really is as simple as a pulley though. But finding one that is smaller, that will fit that thing, might be a problem. Potentiometer or rheostat should work, but some brush motors will flip out at too low a voltage. Burn up. Not sure why.
Are you going down to your shop today? Thought I'd swing by and watch your progress for a bit. Gives me motivation to start on mine. Saw you on Burnside at about 11:00 PM last night.
/edit: Oh yeah, where do you buy gaskets from?
« Last Edit: November 03, 2007, 08:30:53 AM by mlinder »
No.
Offline paulages
  • 1976 cb735
« Reply #168 on: November 03, 2007, 10:39:16 AM »
mark--i'm just gonna try a light dimmer. yeah, larger pulley on the motor would do that--garrett was trying to figure out how to mount the larger pulley to the clutch basket, but that seemed silly to me as the belt worked great with the basket alone.
yes, i'll be down there today. not sure when, though. gimme a call. about the gaskets--not sure of the best price. Z1 usually are best.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #169 on: November 03, 2007, 11:43:44 PM »
we ran the contraption today, and it worked great! i'm starting a thread about it with pictures and video.
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
Re: 650 overbore/550 engine hybrid underway...build beginning soon. finally.
« Reply #170 on: March 12, 2008, 11:04:00 AM »
i finally got my bottom case back from the machine shop. all that is left to do is tap the oil line into the right side of the head. i'll be starting a new topic photo documenting everything necessary to do this conversion. i'll probably wait until the engine is actually complete to do that though, so all of the info will be at the top of the thread. i'd hate to be someone trying to figure this out by reading through this thread...         ::)
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #171 on: March 12, 2008, 11:31:29 AM »
That would be great!
Thanks Paul
Offline paulages
  • 1976 cb735
« Reply #172 on: March 12, 2008, 11:43:03 AM »
by the way-- anybody on here get the dealer discount with megacycle and want to help a friend out?  ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #173 on: March 18, 2008, 10:57:09 AM »
i'm not worrying too much about keeping the photos chronological at this point, as i'll organize them all in a new thread going step-by-step through everything without the in-between banter. here are some pictures of the oiler. the first pic is the 650 case stock:
this is the modified 550 case. the tower for the oiler was made out of solid round stock, drilled out and spotfaced to fit the o-ring. the left three quarters were tig welded, then we used high strength epoxy on the hard to reach parts.
« Last Edit: March 18, 2008, 11:00:25 AM by paulages »
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
Offline paulages
  • 1976 cb735
« Reply #174 on: April 04, 2008, 01:44:23 PM »
i would just like to say that brand new NOS crank, rod, and trans bearings, rod nuts and bolts, seals, chains, circlips, etc. are:
1) such a beautiful thing.
2) such an expensive thing
3) the last stuff i was waiting for to put this engine together!
  ;D ;D ;D ;D ;D ;D ;D ;D
paul
SOHC4 member #1050
1974 CB550 (735cc)
1973 CB750K3
1996 KLX650 R
