Author Topic: Help lower brake line direct in to caliper  (Read 783 times)
Offline heymak
« on: April 03, 2014, 12:52:20 PM »
Please help. I am installing new brake lines, done the top 1 weeks ago when I fitted a new EBC rotor and pads , worked much better than standard rotor and pads.  So I am installing the lower brake line direct to caliper with a banjo and bolt. It's all fits ok. But do I need to remove the conical in the caliper , iff I do can I pull it out or dig it out somehow ? Please help.
« Last Edit: April 03, 2014, 01:09:46 PM by heymak »
Offline heymak
Re: Help lower brake line direct in to caliper
« Reply #1 on: April 03, 2014, 01:00:46 PM »
Pic
« Reply #2 on: April 03, 2014, 01:10:48 PM »
id remove it (insert a screw and pull it out) and put copper crush washers on with the new bolt.
« Reply #3 on: April 03, 2014, 01:24:45 PM »
Agreed, when I did one, I screwed a tapered wood screw into it. Kept turning and the fitting started to spin and pulled right out.
Before I was schooled on removing them I cut the banjo bolt down, and added some washers. Crude but it worked.
Better to extract the cone though.   :D
Offline heymak
« Reply #4 on: April 03, 2014, 03:11:41 PM »
thanks guys ,I will try it in the morning , hope it comes out easy ,
« Reply #5 on: April 03, 2014, 10:17:05 PM »
I bought some short aluminum banjo bolts from a brake line company. speigler I think.
