Author Topic: cable end molds?  (Read 2039 times)
scout18
cable end molds?
« on: September 14, 2006, 09:46:42 PM »
Seems like I read in a magazine a blurb in anarticle about a guy forming his own cable ends. Has anyone here heard of such a mold?  Imean they get made somewhere and from something I want to know how and what cable ends are made from.
USN20
Re: cable end molds?
« Reply #1 on: September 14, 2006, 10:21:06 PM »
Barnett offers cable end fittings for British, Japanese and Harley.
http://www.barnettclutches.com/products/throttle_levers.aspx?cat_id=15&prod_id=85
Offline burmashave
  • Forum Immoderator
    • burmashave.net
« Reply #2 on: September 14, 2006, 10:57:21 PM »
I made and soldered mine myself.  This is the guide I used:
dansmc.com/cables.htm
I went to a couple of hobby shops, but they didn't have the brass stock I needed, so I went to the hardware store and picked up the largest diameter solid brass bolt they had.  Then, I filed down the end to fit, drilled it, used a Dremel to open up the hole on one side, and cut it to length.  I discovered later that it would have been easier to put the bolt in the chuck of a drill press and turn it down with a file.
For the soldering, I used a steel food can and a MAPP gas torch.  This may have been a bit dangerous, given that food cans are not designed for that temp.
That said, I think I'll order a custom cable the next time I need one ;-)
Quote from: SOHC Digger, RIP
'77 CB750k
Offline STLrocker
  • whiskey bent and hell bound
« Reply #3 on: September 15, 2006, 10:32:44 AM »
dont know anything about a mold. i made cable ends from a piece of aluminum rod i had. it was 1/4". i had to file it  little to fit. then i drilled a hole through with a drill press. it was soft aluminum so it filed quickly and drilled easily. then put the cable trrough, spread the end and soldered. its been workiing fine.
scout18
« Reply #4 on: September 15, 2006, 08:57:32 PM »
Wow. Great Ideas. you folks are amazing.
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #5 on: September 16, 2006, 11:45:17 AM »
Yes, thanks for the info.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
