Author Topic: Favourite tools  (Read 1942 times)
Offline Paul Lowe
  • If you like then it is good...
Favourite tools
« on: April 26, 2014, 11:46:47 PM »
I think there may have been a similar thread before but was on the shed cleaning exhaust valves when I thought "I love my wire wheel!"
It's an old Goodall & Pratt with a belt drive off and old motor but gee it works well!
See pics...  Do you have a tool that makes you smile?
My Honda sickness deepens
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
1/2HP electric bike home made...
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
Re: Favourite tools
« Reply #1 on: April 26, 2014, 11:49:54 PM »
 ;D ;D ;D
Build threads:
1977 CB750 F2
1958 Norton Model 99
Re: Favourite tools
« Reply #2 on: April 26, 2014, 11:56:07 PM »
My home-made tools are what I like best. I built a shock absorber spring compressor many years ago, and still use it now. I'll take some pics when I reassemble a set of S&W Street Strokers I painted to go on a bike I'm building for a member at the moment. Cheers, Terry. ;D
Offline Paul Lowe
Re: Favourite tools
« Reply #3 on: April 27, 2014, 12:17:26 AM »
You are right Terry. The old wire wheel is a bit like that salvaged from a scrap bin.
Also high tech like my valve spring compressor!
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Re: Favourite tools
« Reply #4 on: April 27, 2014, 01:14:23 AM »
That's excellent mate, I've got something similar that I cobbled together years ago, and still use! Cheers, Terry. ;D
Offline fmctm1sw
Re: Favourite tools
« Reply #5 on: April 29, 2014, 04:35:30 PM »
air compressor.  have no idea how I lived without it...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Re: Favourite tools
« Reply #6 on: April 29, 2014, 09:11:09 PM »
 ;D ;D ;D
hahahahahah...yuuup!   ;D  ;D  ;D
Offline 333
  • Time for change
Re: Favourite tools
« Reply #7 on: April 29, 2014, 09:36:53 PM »
I like the ones I get for free, usually broken, and fix them.  Mostly wood working tools lately.  I took 3 broken  Porter Cable palm sanders and made 1 good one.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline 333
  • Time for change
Re: Favourite tools
« Reply #8 on: April 30, 2014, 08:08:04 AM »
I got a Sears/Penske compression tester today.  Looks like it's never been used. It's new in the box, but about 30 years old.
And I'm not sure it's worth the time, but I also got a tiny bench grinder, a "Toastmaster".  I thought they only made toasters.  It has some sort of drill bit sharpener (Craftsman) thingy on the side. It has a broken switch.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: Favourite tools
« Reply #9 on: April 30, 2014, 10:44:23 AM »
All the tools that I made that actually work!
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
DH
Re: Favourite tools
« Reply #10 on: April 30, 2014, 03:12:51 PM »
I have 2 favs.............impact driver and the special crimper pliers that came from vintageconnections.com.
ESP. the pliers. Factory style crimps that you might probably be able to hang your body weight from without breaking them. Nice, neat and clean 8) 8)
Offline NobleHops
  • Don ya be callin' me no
  • Misfit - Tucson, Arizona
Re: Favourite tools
« Reply #11 on: April 30, 2014, 03:14:46 PM »
 ;D ;D ;D
<golf clap>
Nicely played sir, nicely played. :-)
I have a motorcycle problem.
Re: Favourite tools
« Reply #12 on: April 30, 2014, 03:44:10 PM »
My 5 minute sub $12 home made valve spring compressor... 8)  not a new design by any stretch, but better and less time consuming than anything sought and bought on the internet :P
Re: Favourite tools
« Reply #13 on: April 30, 2014, 04:50:05 PM »
My 1/4" drive Craftsman ratchet, with small extension and 10mm socket attached.
Seem to use it more than any other tool when working on my bikes.
Offline Paul Lowe
Re: Favourite tools
« Reply #14 on: May 01, 2014, 01:15:42 AM »
Just took delivery of a new Kinchrome ratchet ring combination spanner set today.
Very happy with that but share the love of 1/4" socket set that nearly always has 10mm on it.
CB350F 1972
CB360G 1974
CB750 K1 1971
CT90 K0 1968
C102 1963
C50 1968
C70 1972
C90 1974
CL90 1968
Re: Favourite tools
« Reply #15 on: May 01, 2014, 09:36:25 PM »
My awesome Hazett snap ring pliers
My shop made steering stem puller,
My favorite spoke wrench,  and tire iron (bicycle),
A 85 year old spoke wrench.
Re: Favourite tools
« Reply #16 on: May 03, 2014, 11:25:14 PM »
A couple of weeks ago I was looking around for a pair of shocks for Mike's bike and found an old pair of S&W Street Strokers hanging up in my garage, so I pulled them apart, checked 'em and gave them a re-paint, so today I re-assembled them using my home made spring compressor.
The flash makes the yellow look too light, but they're actually just like the one on the sticker:
I had to make up a home made driver to remove the outer shell of the lower shock bushes, which were still in the swingarm after it was powdercoated.
It worked really well, and I was just able to wind the old shells out. I just used the vice with some "soft Jaws" to press the new bushes in.
That just left the new bronze swingarm bushes. I decided to use the threaded rod method, but machined up some drivers to makes sure they went in nice and straight:
Here's the whole assembly, ready to go:
They wound in nice and easy, with no "mushrooming" to worry about:
Here they are, looking good:
On the frame:
Offline krusty
Re: Favourite tools
« Reply #17 on: May 04, 2014, 12:14:14 AM »
My 4 stone hone. Found it in an antique shop a few years ago. Paid $25 for, I reckon it was a bargain.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Re: Favourite tools
« Reply #18 on: May 04, 2014, 01:29:18 AM »
That is a nice hone Krusty, what brand is it? ;D
Offline krusty
Re: Favourite tools
« Reply #19 on: May 04, 2014, 01:50:51 AM »
No brand or marks on it Terry. Looks like it could have been hand made by a craftsman.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Re: Favourite tools
« Reply #20 on: May 04, 2014, 01:55:31 AM »
I'm pretty sure it's a factory made one Krusty, I've got one out in the garage just like it, but I can't remember what brand mine is. (and it's too cold and wet outside to go look............) Cheers, Terry. ;D
Re: Favourite tools
« Reply #21 on: May 08, 2014, 09:41:20 PM »
My new billet WASPswatter..
Re: Favourite tools
« Reply #22 on: May 09, 2014, 04:59:24 AM »
Are you selling them, Frank?!
Re: Favourite tools
« Reply #23 on: May 09, 2014, 05:14:19 AM »
Noddy..... 8)
Re: Favourite tools
« Reply #24 on: May 10, 2014, 01:04:48 AM »
;D
