Author Topic: My steering dampener saved my life tonight!  (Read 8383 times)
Offline SOHC Digger
  • I'm not an
« on: May 09, 2014, 10:49:33 PM »
I rode my CB750F Chopper to work tonight. As I was heading south on I-55 and exiting onto I-355 south, I hit a massive pothole at about 70 mph. The front wheel came off the ground when it hit. While it was still in the air, the rear wheel hit and came even higher off the ground. I came off the seat and off the pegs. When the front wheel came back down, it started to go into a speed wobble. After about two or three oscillations, however, it straightened out and I was able to regain control. Other than some shaken nerves and a bruised ass, I came away unscathed.
I am certain that without the NHK steering dampener, the speed wobble would have gotten worse and I would have gone down hard. I cannot express enough how thankful I am that I installed that on my bike.
Unless you are doing a concourse restoration, I encourage everyone to install a steering dampener on your bike. They are not difficult to install and may save your life too one day!
« Last Edit: May 09, 2014, 10:57:03 PM by SOHC Digger »
Re: My steering dampener saved my life tonight!
« Reply #1 on: May 09, 2014, 10:54:35 PM »
good advice,if it wasn't a chopper hard tail it might've been even easier to control?dont flame me just saying!
Offline SOHC Digger
  • I'm not an
« Reply #2 on: May 09, 2014, 10:55:52 PM »
Oh believe me, I know! And my ass probably would feel better too!
  • I'm back
« Reply #3 on: May 09, 2014, 11:33:31 PM »
Decades ago I asked my dealer for a steering damper. He could easily have sold me one but replied that I didn't need one. He rode exactly the same bike (CB500). In over 100.000 kms I have never experienced even the beginning of a speed wobble. Bike is almost standard with Koni rear shocks. Don't blame me for dampening your advise somewhat.
« Last Edit: May 09, 2014, 11:36:24 PM by Deltarider »
Online seanbarney41
« Reply #4 on: May 09, 2014, 11:34:26 PM »
I have had similar situations occur without a steering dampener and everything straightend out alright.  Cb750's are stable old bikes.  Nothing wrong with having a steering dampener though.
« Reply #5 on: May 09, 2014, 11:56:14 PM »
they are good,and if tweaked correctly will save a spill in the correct circumstance,mine had one but it made way for dual horns,ive never had a problem,ive often thought about one though if itll give me that extra edge chasing down unsuspecting Harleys through the twisties,ive a wobble or two but nothing that wasn't my fault over rough lumpy tarmac leaned over.
« Reply #6 on: May 10, 2014, 12:52:07 AM »
I like steering dampers because they look cool............. ;D
« Reply #7 on: May 10, 2014, 12:56:38 AM »
I like dual snail horns on a bike because they sound #$%* hot!the unattentive need a wake up!
« Reply #8 on: May 10, 2014, 01:02:54 AM »
Yep I loved the Stebel horns I put on my GS1000 Dave, but they're shiit in a tankslapper! ;D
« Reply #9 on: May 10, 2014, 01:05:58 AM »
tankslappers don't give me a horn!
« Reply #10 on: May 10, 2014, 01:27:02 AM »
I give up, I got nothing............ ;D
Offline kghost
« Reply #11 on: May 10, 2014, 03:25:21 AM »
Hmmm.....I have never had that particular experience on a Honda 4.
Course I don't ride a chopper......Most of my bikes have had the steering heads and suspension gone through.
Had a fair bit of headshake and wobblies on other things.....I was pushing hard and leaned over as Dave mentioned.....
Honestly never felt like I needed a steering dampner on a 750....even one that will wheelie at 40mph.
Stranger in a strange land
  • I'm back
« Reply #12 on: May 10, 2014, 04:32:18 AM »
Ofcourse not. Honda would have fitted one. One would have expected compelling laws. Never heard of any so far.
« Last Edit: May 10, 2014, 04:35:17 AM by Deltarider »
Offline Bailgang
  • Scott
  • Indiana
« Reply #13 on: May 10, 2014, 06:01:39 AM »
An older brother of mine's H2 Kaw had one on it in fact I think it was a factory item but I guess that's why they called the H1 and H2's widow makers. In all the years he owned it (nephew has it now) he only had a tank slapper once and that was when he was messing around with my nephew who was riding a cbr600rr. Later on my nephew tore the H2 down to restore it and found a nasty crack in the frame near an engine mount.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline Whaleman
« Reply #14 on: May 10, 2014, 08:20:56 AM »
I wish someone on this site would put together a simple bolt on kit to use with a stock CB750. Best dampener that screws right to the fork and a good machined frame brace. I would buy it. Dan
« Reply #15 on: May 10, 2014, 09:14:40 AM »
Whaleman, the tree is usually set up for it, bracket for frame for some not hard to make, or simply weld on a tab.
 My damper on cb 750 chopper,
 I loved that Kawi damper on there. If for only this reason,
I ran tapered stem bearings. Set up the way I liked,  in combination with the extra rake, it had a tendency. To flop when parking...ie flop to side sorta hard.
With the damper installed and set up,  I could simply let go of bars and step off the bike,  the first instant the sidestand touched the ground. The forks would then simply sssqqqwwwoooooooge...
 S l o w l y and gently against stop..very nice..
Offline Whaleman
« Reply #16 on: May 10, 2014, 09:18:37 AM »
754, I agree. just don't have time to design and machine a good frame clamp and pick the best unit. I know about the threaded hole in the tree. Do you think a good engineered bolt on kit would sell? Dan
« Reply #17 on: May 10, 2014, 09:40:39 AM »
Glad your ok, Digger, 'cept for a bruised arse.  Need to order one for my Z1.
Offline 750K
« Reply #18 on: May 10, 2014, 10:19:00 AM »
Fast from the Past sells both, I have one on my 77. Took all of 10-15 minutes to instal, I love having one on an old bike. That coupled with a fork brace made such a huge differance in the feel and handling of my 750 and I already have rebuilt the front end, new tires, steering bearings etc etc. Was hugely noticeable, I'll always put them on any vintage Honda or Kawi I own from now on.
77 Cb750, 78 Kz1000
Offline SOHC Digger
  • I'm not an
« Reply #19 on: May 10, 2014, 01:35:24 PM »
Actually, save the money on the damper and move out of IL. The roads there are #$%*e! But I agree with Digger, a damper could save your life in that situation. Best to avoid those potholes...
Yes, the roads here SUCK!!! I was cursing the state dept out the whole ride. I lived in Arizona for three years and the roads there are smooth as silk. Talk about good riding!!!
The steering dampener MIGHT NOT have been the reason the bike came out of the wobble, but it certainly didn't make matters worse. And like Terry said, they look cool ;)
Offline BeSeeingYou
« Reply #20 on: May 10, 2014, 02:49:14 PM »
I think it has a lot to do with the frame geometry.  A bike with a trail of less than 4 inches can benefit from a damper above that it is less critical.  All the bikes I have owned all have a trail in the 4.5 inch range and I haven't the slightest idea what a speed wobble is......in 35 years of riding I have never had one. :)  The K bike is 3.7 so to me it feels twitchy.  I am talking about stock frames here so with a chopper the geometry is altered and it may react differently.
We had a long and hard winter and it really tore up the roads.  I am in no hurry to get out there till some repairs get made.  I can't remember when it was this bad.
« Last Edit: May 10, 2014, 02:58:12 PM by srust58 »
Offline Whaleman
« Reply #21 on: May 10, 2014, 03:59:52 PM »
750K, Which dampener did you get? Did you use their clamp on the frame? Dan
Offline Head
  • JUST SOME OF THEM- I WAS BUILDING THESE WHEN NEW
    • My Bikes
« Reply #22 on: May 10, 2014, 04:15:59 PM »
Digger the thought of that brought back memories and made me pucker a bit. I could hardly walk for a week from a bruised tail bone.
1970x2,71,72,74,75K's,75F-FO-750ss, 2 x 75 GL1000, 77 GL1000,  3x 1981 CB900F, 74 550,  1966 CL77 305, 1967 CL77 305, 1974 MX360 Yamerhamer, 1983 CB1100F RED
NOTICE Due to current financial restraints the
Light at the end of the tunnel will be turned off until further notice!! sohc member#1522
« Reply #23 on: May 10, 2014, 05:59:29 PM »
Actually, Honda offered one as an option mate, and even provided a threaded hole on the lower triple for the installation. They just cheaped out and didn't fit them as standard. Cheers, Terry. ;D
« Reply #24 on: May 10, 2014, 06:25:20 PM »
Wrong, my friend, do you insure your bikes...?   A steering damper is an insurance policy, I have had a couple of underwear changing tank slappers on a very well sorted K2 {for the time}, one caused by a small pot hole and the second worse one was just a crossing a thick painted center line on the road while overtaking at speed, that one very nearly threw me and bruised  my hands, it was very violent, actually while i think of it I have had 2 others on friends bikes as well, one on a H2750 Kawasaki {after the front wheel came down  :o} and another on a GT550 Suzuki {ended up in a reserve on the side of the road}, both know for their less than graceful  handling. My point is, think yourself lucky you haven't had one and maybe be a little more open minded as to why the dampers are a good thing to add on old bikes, Most if not all modern sport bikes have them as standard, also the K model Honda's had relatively small trail numbers at the front, around 3.7? inches, which even by todays standards makes for a nervous front end {most sport bikes are around 4 inches of trail}. The K2 i spoke about earlier received a damper after the second tank slapper and never misbehaved again, it was well set up and ridden hard, I've had dampers on every other 750/4 i've owned and will continue to use them... ;) The old black NHK z900 steering dampers were what i used ...
