Ok, I was using the upright position just so you'd know what exactly to measure, but if the float valve pin is spring loaded, that must be taken into account. At the url above you'll see the measurement must be taken while the carb is held at an angle so that the float tang is touching the valve pin, but not compressing it (as shown in the 2nd and 3rd photos). I am not as familier with the later carbs, but the spring on the valve pin must not be compressed when taking the measurement. There are people on this forum that are very familier with the later carbs, maybe they'll pickup on this thread.
....any float on any carb, whether round or flat will be meaused from the bottom of the float to the bowl gasket surface, or the lip that goes around it.
