Author Topic: Martek 440 documentation needed  (Read 3042 times)
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
« on: September 19, 2006, 04:19:48 PM »
Anyone with the installation docs for the Martek 440 around?  My 750F has the thing installed, but I don't have any paperwork on it, and can't seem to find anything on the web about it.
I know someone out there has it :)  Just need to get a scan of it or something - pretty please?
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Re: Martek 440 documentation needed
« Reply #1 on: September 19, 2006, 05:42:52 PM »
And when they do Glenn, et al needs to include it in this site for reference.
Offline Jugghead
  • I just THINK I'm a
  • 350cc of pure FUN
« Reply #2 on: September 19, 2006, 06:18:03 PM »
Ditto that!
I have searched to no avail for ANY sort of documentation regarding a Martek 440 elec. ignition.
It is installed, works fine, etc.  But do I have the timeing set correctly?  I don't know?
The index mark on it is lined up with the Timing mark on the breaker plate,
but I just want some info on this "little black box"
When found, can it be in the ignition FAQ?
thanks!!
9/72 CB350F...15k miles and rising
« Reply #3 on: September 19, 2006, 06:28:49 PM »
I've got it, I'll post it when I get home. For Juggy, your assumption "The index mark on it is lined up with the Timing mark on the breaker plate" is correct, and there's no requirement to adjust it with a timing light.
The Martek 440S was self contained and there was no black box, but I believe that the later Marteks had ignition amplifiers, (black boxes) but I doubt if there was any adjustment required, I'd imagine it'd be the same as the amplifier on the Dyna 3.
I've got several Marteks and they're quite good, in their day they were rated very highly indeed and were very expensive compared to the Dyna S. The Martek in my F2 has outlived 2 CB750's and it'll be coming out before I sell that bike. Just be very very careful about accidentally connecting the power wire to a signal wire, if you do, you'll fry the module! (as I did on my GS750 ignition, boohoo!) Cheers, Terry. ;D
« Reply #4 on: September 20, 2006, 05:35:11 AM »
Here it is! Cheers, Terry. ;D
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
« Reply #5 on: September 20, 2006, 05:58:21 AM »
Terry
email a hi-res version to me or Glenn and we'll put it in the library (and maybe the FAQs)
Steve
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
