Author Topic: No Power To Starter !!  (Read 3091 times)
Offline sanddigger
« on: June 11, 2014, 10:41:11 AM »
Hi, All its Sanddigger, I am rebuilding my 1977 CB750a ,all most don, Question ?
I have no power to the stater , But Have power to the buttion but the starter
will not turn all the fuse are all OK  >:( ::).
Offline Mr Freeze
Re: No Power To Starter !!
« Reply #1 on: June 11, 2014, 10:42:32 AM »
What about power at the starter solenoid?
Offline sanddigger
« Reply #2 on: June 11, 2014, 10:46:59 AM »
Hi, I For got to say I Have no power  in the solenoid , I  have other one still no power to the starter. :'(
Offline grcamna2
« Reply #3 on: June 11, 2014, 11:13:03 AM »
Do any of the other electrics work? and do you have a good battery & well grounded ?
75' CB400F/'bunch o' parts'
Offline sanddigger
« Reply #4 on: June 11, 2014, 12:59:05 PM »
I have a New battery Lights  work Horn Work Turns Work, but the starter will
not turn ,if you Junp the solenoid it turn over but not by the butten I have power to the butten but will not turn over the engine.
Offline Mr Freeze
« Reply #5 on: June 12, 2014, 12:03:50 PM »
The solenoid is what lets the power flow to the starter for it to turn over the motor. It is activated by the start button. It should have a green/red stripe wire that connects to the start button and a yellow/redstripe wire that connects to ground. The solenoid might be dead?
Offline grcamna2
« Reply #6 on: June 12, 2014, 01:50:42 PM »
There is a safety no-start switch somewhere...possibly the rear hand brake or sidestand ? I'd check the wires to that to be sure you're getting continuity to complete the(black/white wire?)ignition circuit.
Offline stikman
  • Bit of an
« Reply #7 on: June 26, 2015, 03:37:09 PM »
I'm resurrecting this thread because I am having the same issue and couldn't find the answer.  I partially rewired my 77 cb750a and can't get the starter to work other than jumping it directly at the solenoid.  The solenoid should be fine, as it worked before I modified the bike.  I hear tell of a fabled stock wiring setup on the matics that cuts power to the starter.  I believe this is most likely my issue but I don't know which wires are involved in this.  Can someone please shed some light on the matter?  Cheers!
1977 CB750A "High Horse": 836cc, mild porting, custom cam, K5 roundtops, v-stacks...
1973 CB750K D5 plunger frame chopper currently building..
Offline grcamna2
« Reply #8 on: June 26, 2015, 03:59:47 PM »
Do you have a oem Factory Honda service manual w/ a good wiring diagram? take a look at the safety switches and their wiring;also the rear brake pedal/parking brake safety switch may be no good.
Offline stikman
  • Bit of an
Re: No Power To Starter !! [FIXED]
« Reply #9 on: June 27, 2015, 12:58:41 AM »
So I studied some of the wiring diagrams that I could find and figured it out.  To bypass that whole "changing relay" and "solenoid valve" system on these bikes you just run the green/red wire from the starter solenoid to your starter switch (I'm using a turn key instead of a push button), and run the red/yellow wire from the starter solenoid to ground.  Now my electric starter actually works.  No more emergency kick start.   8)
*Note: I am using a tach in place of the stock gauge with the lights for neutral/low/drive, etc.  This probably won't work for anyone wanting to keep that gauge.  Tach is more useful anyway.   :P
