Author Topic: CB650 forks - am I fu**ed?  (Read 1686 times)
Offline henrikm
« on: June 26, 2014, 12:30:28 AM »
Hey guys,
was changing the fork seals on my (new to me) '79 CB650 Z (RC03) last night when #$%* hit the fan. Started off with the right fork and everything went smoothly until I was about to pry the old seal out of it's seat. Without even applying any force a big piece of the lower fork broke off. After going ballistic with bad phrases and wrenches all over I started inspecting a little closer and there is glue residue all over the piece that broke off. The f*in PO apparently just glued it back on when he destroyed them in the first place.
So the question really is what fork lowers will fit my RC03? I'm thinking I want to swap both of them out as I really don't know the condition of the other one. The Z (RC03) is dual disc and the stock fork lowers are black. Parts for the Z model is pretty scarce on ebay so I'm hoping some of the later model forks might fit.
I need to get back on the road as my 750 is undergoing a total rebuild, so as of now I'm stuck with 4 wheels :(
Offline henrikm
Re: CB650 forks - am I fu**ed?
« Reply #1 on: June 26, 2014, 12:51:03 AM »
Actually found one on ebay (from Germany) that might seem to fit. As far as I can tell it's from a 1981. The only thing I can't see on the pic is the fender mounts?
eBay link
« Reply #2 on: June 26, 2014, 01:43:27 AM »
If you still have the broken piece you could weld it back in mate, but if that eBay leg fits, for that price, I'd buy it. Cheers, Terry. ;D
Offline henrikm
« Reply #3 on: June 26, 2014, 02:13:12 AM »
Well, this was allot more dramatic than I first thought.. I don't think I've got nerves for these old bikes. Turned out a guy in the local classic Honda club wanted to trade me a pair of fork legs for a luggage rack I had lying around :)
Good stuff.
« Reply #4 on: June 26, 2014, 04:39:30 AM »
Sounds like you made out very well on that trade    ;)
Offline fmctm1sw
« Reply #5 on: June 26, 2014, 12:30:35 PM »
Don't pry them out.  Take out that retaining ring on top of the seal and take out the hex bolt on the bottom.  Jerk the upper fork like a dent puller and it will pop the seal out.  Unless the 650Z is different from the 650C and 650 standard I did.
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Offline henrikm
« Reply #6 on: June 26, 2014, 10:20:36 PM »
Thanks, I'll give that a shot on the next fork I do.
Offline lucky
« Reply #7 on: June 27, 2014, 12:12:40 AM »
WOW!!! You could have been killed when riding.
This was very lucky that you made this discovery.
I do not like people that sell things with known defects.
Like car manufacturers, and computer companies.
« Reply #8 on: June 27, 2014, 01:49:13 AM »
And breweries........... ;D
« Reply #9 on: June 27, 2014, 07:46:38 AM »
I know you no longer need one, but can you show the brake mount..looks a lot like 77/78 f legs..
Offline henrikm
« Reply #10 on: June 28, 2014, 06:27:19 AM »
Here's a pic of the fork.. I think it must have been black from the factory, or the PO have had them professionally painted.
While waiting for a new fork lower, I'm trying to finish the powder coating oven I'm building :)
« Last Edit: June 28, 2014, 06:28:51 AM by henrikm »
Offline trueblue
« Reply #11 on: June 28, 2014, 06:33:34 AM »
They are very similar to the F legs Frank. But I think the differ slightly in length from memory.  IIRC they are interchangeable but as a pair only otherwise you'll see the difference. ;D
1979 CB650Z
