Author Topic: Paint Disaster  (Read 4148 times)
Offline iron_worker
Paint Disaster
« on: June 28, 2014, 03:25:17 PM »
So my lovely paint job went from immaculate:
...to this...
..to THIS  :o ...
What the *&&%?! It started as a tiny bubble right under the gas cap which I was pissed about but figured I could deal with because at least it was covered by the cap. Then it spread ... and then it spread more and quickly!
I didn't put 2 and 2 together but each time I filled up my tank is when it got worse quicker... I think I finally figured it out today. Is it possible to have a pin hole leak where your filler neck attaches to the main tank body?
My only other guess is my that maybe my vent is plugged. It's pretty warm out today and could hear it sort of releasing pressure. Would that cause this?!
I'm not really too sure where to go from here. Any suggestions? Obviously it needs to be repainted (ugh... was a huge pain in my @ss dealing with a POS paint shop the first time round).
Pretty depressed right about now. :(
IW
Re: Paint Disaster
« Reply #1 on: June 28, 2014, 03:34:06 PM »
Gee sorry to see that for you. Might be leaking around the cap seal also. Did the body shop give you any assurances about it being gas resistant at all and was it clear coated over the paint ? What kind or brand of paint is that ?  I like you would be very depressed about it also.
Offline iron_worker
Re: Paint Disaster
« Reply #2 on: June 28, 2014, 03:43:20 PM »
Anyone ever hear of a leak at the filler neck connection before?
How does one check if the vent is clear/working?
I am sure it was cleared. The paint is the factory paint from a Rousch Mustang actually.
Don't laugh but what actually happened was the first time they painted the colors backwards the first time (red around the Honda logo and black on the main body of the tank ... ugh ... He tried to save the decal since he'd already screwed up the original one and had to pay a custom decal shop to make another one when he probably should have just sand it all down and started over. I'm guessing they rushed the prep and that's why the red is coming off so easy now. Oh ya and they took 4 months to do the job when they said it would take a couple weeks.
Did I mention that they suck and I hate them?  >:(
IW
Offline ozpacman
Re: Paint Disaster
« Reply #3 on: June 28, 2014, 04:06:38 PM »
I wouldn't be to hasty in blaming the painter.  You clearly have a fuel weep that is seeping under the finish and lifting it off.  All the paint preparation in the world is not going to stop what's occurred on your tank.
A mate of mine once removed the fuel tank of his then new Harley and sat it on a towel which he then folded back over the tank to protect it while it was off the bike.  The fuel inside the tank slowly leaked out around the equaliser tube at the lower front of the tank as he hadn't tightened the clamp sufficiently.  The fuel slowly seeped onto the towel which then wicked upwards and left one side of his tank looking exactly like the top of your tank.
Like you - he wasn't too happy either . . .
Russ
Offline Killer Canary
  • Typical Bran Muffin
Re: Paint Disaster
« Reply #4 on: June 28, 2014, 04:30:27 PM »
Your painter would have been wise to clear coat beyond the paint in that area. Looked very nice for a while. :-\
Kawi GPz900, H1
Offline iron_worker
Re: Paint Disaster
« Reply #5 on: June 28, 2014, 04:33:13 PM »
Ya I guess the clear is probably fuel resistant but if it really soaks on there it's only a matter of time.
My theory as to what happened is this:
It didn't used to leak fuel before I painted it but during the rebuild I stripped out the failing liner and soaked it in vinegar to remove all the rust. So it probably had enough rust and/or just enough sealer left up there to keep it from leaking.
So the question is ... is it cheaper to try and fix (have it rebrazed?) this one or find a new tank? I actually happen to have another tank (with an extra crappy paint job).
IW
Offline iron_worker
Re: Paint Disaster
« Reply #6 on: June 28, 2014, 04:36:40 PM »
Yes, this was another question I had. They had painted right up and over the top of the filler neck which of course started getting real soft as soon as I filled it up the first time. I scraped the paint back so it would start outside of where the rubber gasket seals.
What is the proper place to end the paint at the filler neck so it isn't harmed by the fuel?
IW
Re: Paint Disaster
« Reply #7 on: June 28, 2014, 04:42:22 PM »
I only tape off the sealing area and clear the entire neck, sans paint. On a proper planet, your painter would make it right. They should have known that this would happen.
Kawi GPz900, H1
Re: Paint Disaster
« Reply #8 on: June 28, 2014, 05:07:11 PM »
I doubt the neck is leaking.  If it was, you would see the primer coming off too.  I think this is caused by the cap venting properly, i.e. the gas fumes have triggered the paint to fail because of improper adhesion between the primer/substrate and the base coat...or a poor quality primer.  Every paint job I have seen since the advent of ethanol gas with paint on the filler neck has failed here...but the damage usually has stopped at the filler neck.
Offline iron_worker
Re: Paint Disaster
« Reply #9 on: June 28, 2014, 05:19:28 PM »
The reason why I think the neck is leaking is because this morning when I checked it out the paint had really peeled back and it was actually wet looking and you could smell fuel on the outside. I had filled the tank up the night before and it was right up .. the fuel level was up over the filler neck/tank connection towards the back.
IW
Offline iron_worker
Re: Paint Disaster
« Reply #10 on: June 28, 2014, 05:22:01 PM »
Here's your answer. If it were me, I'd re-line the tank, then have it re painted. I personally have had no problems with painting the neck, but I do strongly recommend NOT painting the lip that seals against the cap seal.
I differ on the cause than some others, I believe the leak is from the neck seam. Fairly obvious from my perspective as to where it began and where it's continuing. Once you drain the tank, dry it inside and out fully. Then, apply tissue around the neck at the bottom. Fill tank with water and see if it is indeed leaking. Simple proof. If it leaks, line it.
I would like to avoid a liner if possible but maybe not an option. Wonder if I could get a rad shop to braze it? They'd have to steam clean it or something first I guess to avoid a large boom. lol
Offline iron_worker
Re: Paint Disaster
« Reply #11 on: June 28, 2014, 05:34:33 PM »
I just have read a lot of liner horror stories and I know how much of a PITA my failing liner was to remove ...
Bah, what a #$%*ty problem to have.
IW
Offline iron_worker
Re: Paint Disaster
« Reply #12 on: June 28, 2014, 05:42:14 PM »
Well that would have been good to know before. lol I used paint stripper and steel wool on the end of a coat hanger... it took several rounds of that.
Well maybe I will look into the Caswell kits. Thanks for your help.
IW
Offline Garage_guy_chris
Re: Paint Disaster
« Reply #13 on: June 28, 2014, 06:02:45 PM »
i had a CB450 tank leak on one of the pinch / weld seams and it did exactly that, it bubbled and lifted the paint and primer.
Re: Paint Disaster
« Reply #14 on: June 28, 2014, 06:31:12 PM »
Not trying to slam you, but the only time of would ever fill a tank right up,  is if I immediately. Got on it, and ran it enough to lower the level..
 One reason. Would be that cool gas coming out of the ground can expand as it warms..
 Any tank filled right up, can lose fuel easier than normal
Offline iron_worker
Re: Paint Disaster
« Reply #15 on: June 28, 2014, 06:44:27 PM »
Ya I guess I didn't really think about that. I usually try to keep it topped up to keep the rust at bay... apparently you can have too much of a good thing!  :o
IW
AJK
Re: Paint Disaster
« Reply #16 on: June 28, 2014, 07:02:33 PM »
I agree with everything CalJ said regarding the filling with water to test, except i would prefer to test with a tank of fuel than water, because fuel being thinner will find gaps that the water may not.
 It also looks like the old liner was perhaps sealing something around there, and by stripping it out, it may have revealed the hole it once sealed. Just a possibility anyhow.
  Also fully agree with 754 on the fuel level on during a fill-up. Last week, i filled it quite near the top, then rode it home. Half an hour later i smell petrol (gas) in the garage, look around and the top of my tank is all wet. I don't usually fill it that high but this time i must had been extra keen. Make sure you leave a sufficient air gap, or like 754 says to take it for a good & lengthly ride. Definitely won't do that again.
  Yeah, that outcome would depress me as well. If your 'other' tank is servicable, i'd just do a quick and dirty spray job with some cans with it while you get your original re-done.
Offline lucky
Re: Paint Disaster
« Reply #17 on: June 28, 2014, 09:02:32 PM »
Did you put MAX2K two part clear over it to make it fuel proof?
Is the tank lined?
Offline Gordon
  • 750K1, 550K2
Re: Paint Disaster
« Reply #18 on: June 28, 2014, 09:23:10 PM »
That's the first thing I thought of when I saw the picture, too.  If the color and the clear both go right to the edge of the filler neck, the gas will wick its way under the clear through the color.
Offline Trad
Re: Paint Disaster
« Reply #19 on: June 28, 2014, 09:25:54 PM »
Is the tank lined?
I love that stuff.
74 CB550 Build: NOS-GUTTED-OEMplus-HOLDTRUE
http://forums.sohc4.net/index.php/topic,130575.0.html
Offline nokrome
Re: Paint Disaster
« Reply #20 on: June 28, 2014, 10:04:16 PM »
How long after the tank was painted until you put gas in it?
  maybe the paint didn't have time to fully cure.
I used the POR tank liner about 5 years ago and it it still looks perfect
Funny thing about regret is...... its better to regret something you have done than to regret something you haven't done.
Offline PGF550F
Re: Paint Disaster
« Reply #21 on: June 28, 2014, 10:53:29 PM »
Sorry to hear about your luck IW, I remember reading about the headaches you were having getting that thing painted in your build thread. Hope you get some recourse with your paint shop, certainly won't be heading up to stoon for any paint needs! :-[ good luck!
Re: Paint Disaster
« Reply #22 on: June 28, 2014, 11:33:55 PM »
I believe this may be the longest duration reported tank liner success story
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
Re: Paint Disaster
« Reply #23 on: June 29, 2014, 08:33:58 AM »
There are quite a few unknowns to be jumping to clear speculation and conclusions as to what went wrong.  Questions I would want answered if I was diagnosing the problem.  First, adhesion comes in two flavors, depends entirely on the type of paint....mechanical and chemical.  The old cellulose and acrylic lacquers are the easiest to envision of the chemical type....each coat melts into the one below. due to solvent softening.
Anyway....not all clear urethane systems are equal. Poly or Acrylic?  Advantages and disadvantages to both.  Poly can be one part or two part.  Both are tricky to apply to water based color coats (current automotive system technology) and work best if an epoxy component is used.  Poly takes almost twice as long to cross link as Acrylic and the cross linking is what makes a 2k Poly so close to bullet proof.  Lack of cure can surely result in de-lamination when contaminants (gasoline) are introduced too soon.   Of concern to me, is whether or not the guy with the gun allows the right amount of flash time between coats.  Too much distance between the color coats and the clear.....poor adhesion.  Today's paint systems are far less tolerant of deviance from the ideal process than they were years back and have re-coat timing windows specified as well as thickness specs for each coat.   I'd start right now with taking that tank to two more shops and getting an autopsy from their best painter before you proceed.  If you get some sort of consensus, then you can approach the old painter for a fix, or find a new one that can.  Until you know what the problem really is....no way in hell you can take steps to fix it.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Re: Paint Disaster
« Reply #24 on: June 29, 2014, 09:06:29 AM »
Cal, I actually have no personal experience with tank liners because I have never had a tank that needed it.  I once worked on an original paint xs650 for a buddy with a rusty tank, treated it with vinegar, which I love because it will not harm paint.  It developed some pinholes.  Pinholes were covered by the forward edge of the seat so I had a skilled buddy tig 'em up...done.
     BMW probably developed some super top secret nazi coating that was applied in a super clean, environmentally controlled vacuum to a brand new tank.  That's not really relevant to our neglected old jap bike situations here...and the one BMW tank I was ever interested in enough to peek into was not lined.  I believe it was an early '70's toaster tank but BMW's are not interesting to me so I don't know much about them.
     My problem with liners is, even if only 1 out of 100 fail, that one is gonna be a #$%* to fix, plus what it does to the carbs...and I see no use for it with steel tanks.  Last time I needed a tank, I bought an old rusty one from Tews for $40, cleaned it with vinegar, had it painted, and USED it for over 2 years and at least 30,000 miles.  It is still fine inside and out.  If you have to paint it anyway, $40 is about the same price as Caswell or POR15 kit
     I look at a lot of old tanks at swap meets and such.  If it was lined more than 10 years ago, it is most likely Cream or Redcoat, and has failed.  All my bikes have somehow managed to survive for at least 30 years and I hope they survive for at least 30 more.  Hopefully, Caswell and POR15 make a superior product now, but they just have not been around long enough to see the long term results, especially when widespread use of ethanol fuel additives have only been around for what?, 5-8 years or so?
    Our biggest selection of information is this here internet.  Unfortunately, very little of it is credible.  Guy posts about tank lining, 6 months later he puts gas in it, 6 months after that he actually gets the over-priced hacked to death pos to run long enough to ride it a couple times, project complete, mostly won't ever hear from him again.   Apologies for the cynicism, but we are looking for long term answers based on short term evidence.  So, without much credible long term evidence, I will stick with what I see with my own eyes in real non-internet life.
