Since you are both using the emgo harness, where are you guys getting power to he taillight from? I had a thread going because when I jump brown to black I have issues with my blinkers staying on. When the jumper is unplugged, my blinkers work like they should, but no taillight.
Sent from my A0001 using Tapatalk
Mine may not be an EMGO one Seth, it worked out perfectly and the only REAL issue there was, wasn't even a part of the harness. The K2 has a simpler wiring towards the rear, and only one oddity at the front, so overall it wasn't bad to hook it all up. Everything was accounted for except for the extra brown wire, which is only for the Euro bikes.
My taillight had always been working, I was dumb enough to not go behind the bike and take a good look. It is powered by the brown/white wire at the rat's nest, followed by the brown wire to the tail light, and these are connected THROUGH THE KEY SWITCH, so that connection isn't so obvious. The winkers, at least from my experience, its best to get them fully operational first then debug the rest.
I thought I had but this wiring harness is causing me hell. I have many of the same issues Rafi is having over in the ice cream build.
Turned out to be zero issues with the harness itself, the one issue was outside of the harness. So you're troubles aren't the quite the same as mine
I have two wiring diagrams and a multi meter. I'm not randomly connecting things, I'm following the schematics. This harness has connectors on it that don't even exist in the wiring diagram.
Sent from my LGLS740 using Tapatalk
Save the ones that don't match up for the very end. Give this a try
http://forums.sohc4.net/index.php/topic,110411.0.html
