Author Topic: 1980 CB650A Swing Arm Bushings  (Read 939 times)
Offline Tdinova
« on: July 12, 2014, 08:05:31 AM »
My sons 1980 CB650A rear wheel is loose when pushing back and forth while on the kick stand. The axle and swing arm axles are tight. I found the part number 52108-460-300 on the net. I called Honda and it is no longer stocked.. Anyone have a source?
« Last Edit: July 12, 2014, 05:53:28 PM by Tdinova »
Blair
Nova Scotia, Canada
Offline MiGhost
  • What was that about being an
Re: REar Swing Arm Bushings
« Reply #1 on: July 12, 2014, 05:38:26 PM »
You will need the following parts to do a complete rebuild of the swingarm bushings/
2 - 52108-460-300 - BUSH, RR. SWINGARM
1 - 52141-460-000 - COLLAR, RR. SWINGARM CENTER
2 - 52144-460-003 - CAP, DUST SEAL - These can be used parts if they are in good condition with the rubber seal still intact.
Option 1:
Check with your local honda dealer to see if they can do a national dealer stock search.
Option 2:
David Silver Spares show the bushings as special order only. Search by part#
CMSNL show 1 bushing, 2 collars, and 2 dust seal caps available
Option 3:
Otherwise you can try to locate NOS parts on ebay, but be prepared to pay dearly if you find any.
~ Ghost
Grey Ghost '80 CB650C: Updated Stock Restomod. Period Custom Cruiser (OEM harbags & trunk, Wixom Ranger fairing, Jardine turnouts)
Bad Moon '83 XJ750MK Midnight Maxim: Full Dress Tour Deluxe w/ X-1 Fairing
Offline Tdinova
Re: 1980 CB650A Swing Arm Bushings
« Reply #2 on: July 13, 2014, 10:16:56 AM »
anyone
Blair
Nova Scotia, Canada
Offline Tdinova
« Reply #3 on: July 14, 2014, 11:59:23 AM »
The Honda god is half listening to me. The local Honda dealer had 1 in stock.. So they are out there..
I have the swing arm off and going to replace the one that looks worn out the most.
 got to find 1 more...some wheres ... Honda god r u listening
« Last Edit: July 14, 2014, 06:34:34 PM by Tdinova »
Blair
Nova Scotia, Canada
Offline Tdinova
« Reply #4 on: July 14, 2014, 12:33:56 PM »
I am trying to remove the old bushing but having problems removing the most worn out one.
1. Remove  the inner collar
2. 1st tried using a long punch, laid it on the inner edge from the other side of the old bushing and hit it with a hammer... no luck
3. Heated the swing arm abit with a torch... not alot just enough to expand the frame, -- tried punch again...
4...... Help before I do something wrong
5... started a search on removing it
anyone
Blair
Nova Scotia, Canada
