Author Topic: 550K1 cases won't quite split  (Read 608 times)
Offline saxamaphone
« on: August 08, 2014, 10:47:56 AM »
Hi guys, hope everyone's summer is going well.  I'm splitting the cases on my CB550K1.  All the bolts are out and just got the rotor off with the Honda tool.  I can pull the cases apart about 3/4 of a centimeter but there is something catching and I don't want to force anything obviously.  It seems like it's something to do with the crankshaft.
I was wondering if anyone can tell me what I'm missing?
Thanks
1975 CB550K1, 1973 CB450K6
Offline straat-toe
  • Everybody knows about the bird.
Re: 550K1 cases won't quite split
« Reply #1 on: August 08, 2014, 12:18:32 PM »
If all the bolts are out it should just pull apart. You get the secret 6mm bolt under the sump? Theres also a sneaky 8mm at the front that might be hidden by dirt....don't ask me how I know.
No School, No Job, No Worries.
Offline saxamaphone
« Reply #2 on: August 08, 2014, 12:24:17 PM »
I know what you mean...
The bolts are out and the cases come apart but only a third of an inch. Something stops them coming apart at that point and I don't want to force them.
« Reply #3 on: August 09, 2014, 02:26:56 AM »
Have you removed the oiul strainer with its extra rubber pipe?
Offline saxamaphone
« Reply #4 on: August 21, 2014, 07:45:44 PM »
Thanks Bryan, it ended up being the left side seal on the crankshaft.  It was glued to the upper case.  Just had to pry it loose.   :-[
