Author Topic: Tank Emblems - Has anybody tried to paint them?  (Read 2806 times)
Offline jmelche2
  • 1974 CB550
« on: August 29, 2014, 03:08:12 PM »
Just wondering if anybody has tried to paint these.  If so, what kind of paint did you use.  All of the black is gone and most of the white.  Thanks, Jim
« Last Edit: August 29, 2014, 03:14:06 PM by jmelche2 »
Offline Jimsun
Re: Tank Emblems - Has anybody tried to paint them?
« Reply #1 on: August 29, 2014, 03:26:29 PM »
Use paint market.
I painted the whole thing to match the tank first. Then painted the letters black.
You can paint the whole thing black and remove the paint where the letters are
74 cb550
Offline Vinhead1957
« Reply #2 on: August 29, 2014, 04:23:52 PM »
I stripped them painted black, fine sanded the paint off the letters and used testors on the inside of the letters then clear coated.
« Reply #3 on: August 29, 2014, 05:31:06 PM »
Paint sharpies.
« Reply #4 on: August 29, 2014, 05:36:57 PM »
I think there is a thread on using those syringes people use to make sun catchers. It is close to the way they were made. The paint is flowed into the letters and allowed to dry. I will do it this winter and post a tread.
Offline jmelche2
  • 1974 CB550
« Reply #5 on: August 30, 2014, 03:54:53 AM »
Here is the thread with some other good ideas..
http://forums.sohc4.net/index.php?topic=136738.msg1541684#msg1541684
« Reply #6 on: August 30, 2014, 04:44:55 AM »
That is how I have done mine using a block of wood and some #400 wet/dry to hit the high spots between color applications. Pretty hard to keep the paint in the 'lines'.
Offline edwardmorris
  • Youngish
« Reply #7 on: August 30, 2014, 05:25:20 PM »
Offline jmelche2
  • 1974 CB550
« Reply #8 on: August 31, 2014, 08:27:57 AM »
Here is the "After" picture using Testors paint.  Not perfect but will do.
Not to hijack my own thread but what are you guys doing with the nasty looking chrome trim?  I'm hesitant to remove them because I'm not sure of what's underneath.  Once I take them off, they're done with.  Thanks
« Last Edit: August 31, 2014, 08:34:02 AM by jmelche2 »
Offline Powderman
« Reply #9 on: August 31, 2014, 09:50:53 AM »
I know it's not a Honda, but I did a set of these for a customer with a Sparkle Silver/clear coat backing, Red letters and then sanded with 1500 the edges and the 850. All powder coated.
Offline kjs
« Reply #10 on: September 01, 2014, 07:13:45 AM »
I replaced the trim on my tank with this http://www.ebay.com/itm/120983035836?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Cleaned up the gunk and buildup a bit before putting in on.  Took about 30 seconds.
Offline jmelche2
  • 1974 CB550
« Reply #11 on: September 01, 2014, 10:47:28 AM »
Used door edge guard.  Looks great
Offline chinaski
« Reply #12 on: September 01, 2014, 05:54:02 PM »
I used acrylic paint I got from an art store. Water soluble, dries permanent and water resistant. Came out great.
1976 CB750K6 :: 836cc :: 4-1 :: Stock airbox
