Author Topic: cb750a gas tank disassembly / assembly  (Read 1994 times)
Offline hazardus320
« on: September 05, 2014, 04:19:04 PM »
Hi guys, I am sure some of you have come across this when doing your bikes.  I was wondering if there is a good way to disassemble and in turn re-assemble the gas tank. More specifically the gas gauge part of it, on the right in the pictures.
Online raymond10078
  • Moderator
  • Just learnin' as I go . . . .
Re: cb750a gas tank disassembly / assembly
« Reply #1 on: September 05, 2014, 04:41:39 PM »
Rotate the locking ring, and it will come right out.
1978 CB750A (upgrading very, very slowly)
Past bikes - Honda: SL350, CX650C, CB900C, CB1000C, CM450A; Kawasaki: several 1972 750 H2's; Suzuki: TC90J.
Bikes I want: CX650ED, a mid-sized japanese V-twin with ABS.
Offline hazardus320
« Reply #2 on: September 05, 2014, 04:46:45 PM »
Is there a good way to re-assemble? I took it apart the other day, without the 50mm lock nut wrench that the book suggests because i dont want to spend $75 on a tool i will only use 1 or 2 times.  Thanks for the speedy reply!
Online raymond10078
  • Moderator
« Reply #3 on: September 05, 2014, 05:02:58 PM »
I've always just tapped it back on with a small hammer....
Offline hazardus320
« Reply #4 on: September 05, 2014, 05:15:33 PM »
Ok, thanks Kandrtech, i will give that a try.
