Author Topic: Headlight conversion?  (Read 1613 times)
Offline xntrik
« on: September 21, 2014, 01:19:32 AM »
Has anyone converted their headlight reflector to an h4? Is this just an off the shelf 7"? Thanks
Re: Headlight conversion?
« Reply #1 on: September 21, 2014, 04:21:27 AM »
Yeah, you just plug it in.
The original handlebar controls are not built to handle the current. To do it properly, relays for headlight are recommended.
Offline xntrik
« Reply #2 on: September 21, 2014, 11:23:11 AM »
Thank you! I'll order one up. I'm planning on either an h4 with lower wattage, or drop in led conversion.... I used an led on my CB350, and it's worked well thus far. Thanks again!
Offline xntrik
« Reply #3 on: September 30, 2014, 11:13:27 PM »
I finished my upgrade earlier today, and just got done riding about 30-45 min at nigh. I used the "CWC-7006" H4 lens with a 45/45 h4 and it's not too bad. Obviously not as good as a 60/55, but beam and spread both high and low are very adequate. I believe the stocker is 50/45w, and it the new bulb didn't seem to drain anything. DEFINATELY an upgrade to do for $17.00. I did have to do some squishing to get the trim ring/headlight carrier to seat correctly. The assembly as a whole seems to fit better in the bucket as it looks like it's a little more shallow than the original.
