Author Topic: cb350 four cylinders 1(most left) and 4(most right) not firing  (Read 13365 times)
Offline Dos
  • Owner of a cb350f
Re: cb350 four cylinders 1(most left) and 4(most right) not firing
« Reply #25 on: October 08, 2014, 04:01:01 PM »
I'm having a hard time loosening the point gap screw.. I don't want to strip the thing.. When it does spark its orange compared to the left side that has white sparks. Maybe it could be the condenser? I'm going to fix the gap first. I have to set it to F and then I can loosen
Offline Dos
  • Owner of a cb350f
« Reply #26 on: October 08, 2014, 05:33:58 PM »
Put in a new condenser and points from another bike..nothing
Offline Dos
  • Owner of a cb350f
« Reply #27 on: October 09, 2014, 02:07:09 PM »
Sorry guys don't mean to annoy you and I may be a novice but I'm trying hard with the tools I got.. So far I have changed spark plugs, checked spark plug caps, swapped coil cords with opposite coil, changed right side points , swapped out both condensers and still nothing. I have drained the oil yet. Battery is running low .. Also, I'm getting backfires now
« Reply #28 on: October 09, 2014, 02:36:06 PM »
was the yellow points wire in contact with the points plate?  did you verify in the dark that a spark is not jumping there?
D8EA plugs, yes?
What was your ohm reading on your caps?  did you cut the wire back some?
what about valve lash?  .002" IN and .003 EXH
what did you set your points gap at?
Carb clened and float height checked?
Offline Dos
  • Owner of a cb350f
« Reply #29 on: October 09, 2014, 02:47:01 PM »
Yellow wire was not in contact
In the dark there is sometimes a spark but it's orangey
I'll have to borrow my friends multi meter again but i will get back soon
Offline Dos
  • Owner of a cb350f
« Reply #30 on: October 09, 2014, 02:49:19 PM »
Also carb 1(most left) has always leaked gas from exit tubes. It stops when it's ridden.. Gas is coming out of it Noe when I try to start it not a lot though
Offline Davidov
  • 1978 CB750 F3
    • My CB750F project log
« Reply #31 on: October 10, 2014, 09:50:18 AM »
Check resistance across the coil.
Use this one. Don't worry about the number in this video. The procedure is what I'm getting you to see.
http://www.youtube.com/watch?v=xJMkt-MESHI
« Last Edit: October 14, 2014, 07:39:20 AM by Davidov »
-David
« Reply #32 on: October 10, 2014, 10:05:27 AM »
Also carb 1(most left) has always leaked gas from exit tubes. It stops when it's ridden. Gas is coming out of it Noe when I try to start it not a lot though
the 350F float valves have a metal tip, and over time, they can wear their seal out against the float valve seat.  If they need replacing, they should be replaced as a set.
Debris in your gas can also lodge here, and hold the valve open, causing drips.  clean tank+working filter=clean carbs.  You'll also need to verify that your floats are set properly.  24mm is correct, not 21mm as noted in several places.
24mm holds the fuel at the correct level in the bowls (3-4mm below bolw gasket seam) often times this corrects any overflow.
« Reply #33 on: October 10, 2014, 10:09:44 AM »
http://www.youtube.com/watch?v=rRQ45lT2d3c
If you use this procedure for testing SOHC4 coils, every single one will test bad, including a brand new one.
Offline Dos
  • Owner of a cb350f
« Reply #34 on: October 10, 2014, 01:35:07 PM »
I feel like it is definitely coil related. How can I properly check
« Reply #35 on: October 10, 2014, 01:45:33 PM »
Have you looked at the FAQ?
Primary should measure about 4.7 -ish ohms.
Secondary should measure about 15,000 ohms.  Neither primary nor secondary should connect to each other, so resistance = infinity is normal for SOHC4 coils.
The coils aren't magic.
Offline Dos
  • Owner of a cb350f
« Reply #36 on: October 10, 2014, 02:16:34 PM »
Yeah I have to just get a good multimeter. But good news I started her up and its sparking I took a picture while it was running. It is definitely the right point so I'm guessing that would go to the right coil
Offline xtravbx
« Reply #37 on: October 10, 2014, 05:32:17 PM »
Where do you live?
Offline Davidov
  • 1978 CB750 F3
« Reply #38 on: October 11, 2014, 11:17:18 AM »
Oops, forgot I found that during my 350 twin adventure. That would be misleading.
Dos, you really need to look these specs over first before you "feel" like it's coil related.
That picture shows sparking on the points plate? You need to see spark at the spark plug.
-David
Offline Dos
  • Owner of a cb350f
« Reply #39 on: October 11, 2014, 08:35:35 PM »
Man this is just one thing after another lol. Battery died I gotta charge it now but I'll test all 4 spark plugs once its back up.
Offline Dos
  • Owner of a cb350f
« Reply #40 on: October 11, 2014, 08:37:09 PM »
My cam chain tensioner bolt snapped off as well. So the screw is keeping the can chain at the right tension but it's stuck in there the head came off
Offline Davidov
  • 1978 CB750 F3
« Reply #41 on: October 12, 2014, 04:00:25 PM »
Your sentences are confusing.
So you have no spark out of the coil for 1 and 4?
-David
Offline Dos
  • Owner of a cb350f
« Reply #42 on: October 12, 2014, 04:09:41 PM »
Sorry. No I have spark coming for 1 and 4 and not 2 and 3
Offline Dos
  • Owner of a cb350f
« Reply #43 on: October 12, 2014, 04:19:54 PM »
This is driving me crazy. Coils 1 and 2 show a reading of 4.5 ohms from the two little output wires.
« Reply #44 on: October 12, 2014, 04:33:13 PM »
One tiny step at a time, eh?
Step one of two show a good coil so far.
Offline Dos
  • Owner of a cb350f
« Reply #45 on: October 12, 2014, 05:22:21 PM »
I'm sorry. Okay so the coil on the left side is shoeing 4.5 ohms and that's when I stick the two prongs into the tiny connectors. The right coil is also the same. However the coil on the left side goes to cylinders 2 and 3 and the spark plugs don't fire when I test. The coil on the right that goes to cylinders 1 and 4 does.. Now I switched the connectors to the opposite sides and when I tried to electric start the bike shut off.. I can't turn it on there is no ignition light now.. I charged the Battery all day. I look at the rectifier which looks likes crap and one wire going into it looks like it melted and the wires are frizling apart.. I am at a loss idk what to do lol. I took the rectifier apart and I'm not to sure if I assembled it back together correctly
« Reply #46 on: October 12, 2014, 07:16:57 PM »
If you aren't going to read these posts, you probably aren't going to fix it with our help.
You have to measure the coil output resistance too, as I instructed earlier.  Then you can eliminate the coil as a problem source.  You can also (in addition) measure voltage across the points, both when they are open and when they are closed, and report the readings.
Less flail, more plodding, picking away at the unknowns, to build a store of knowns about the bike.
Offline Dos
  • Owner of a cb350f
« Reply #47 on: October 12, 2014, 07:33:49 PM »
Will do. How do I measure the resistance? I'm a little confused on how to test. There are 2 pins a female and male and I stick the negative and positive prongs on them and get the 5 ohms reading. I'm guessing that's the primary coil? How do I test the secondary?  There are two spark plug chords going out and two thickle metal prongs on either side I'll take a pic
« Last Edit: October 12, 2014, 07:35:59 PM by Dos »
« Reply #48 on: October 13, 2014, 01:30:32 AM »
Ever read the FAQ?
Or, do you insist we type out the procedure again here?
« Reply #49 on: October 13, 2014, 01:49:51 AM »
you can do it loyd!
