Author Topic: Pulse Generator or Ignition Coil  (Read 2954 times)
Offline braincube
« on: October 13, 2014, 11:25:15 PM »
Hi guys! It's been awhile!
I'm still struggling through some work on an '82 CB650 that won't start. I thought it was the fuel system, couldn't troubleshoot it, got impatient and brought it to a shop. They notified me of no compression in two of four cylinders - and that it needed a full top-end rebuild.
So, I did it myself. The full top-end rebuild - everything went really well. And still, the motorcycle won't start. Carbs are getting fuel, but the spark plugs are firing weird. Spark plugs connected to cylinders 2 and 3, connected to the RHS ignition coil, fire repeatedly (normal). Spark plugs connected to cylinders 1 and 4, connected to the LHS ignition coil, fire once and then remain dead. Could the problem be the pulse generator? I noticed one of the black plastic units of the pulse generator has unseated from the metal plate.
How do I test for failure of the pulse generator or failure of the ignition coil?
Re: Pulse Generator or Ignition Coil
« Reply #1 on: October 14, 2014, 01:08:11 AM »
got a multimeter?
Offline braincube
« Reply #2 on: October 14, 2014, 08:02:16 AM »
Yeah, now how do I use it?
KiefRichards
« Reply #3 on: October 14, 2014, 09:48:31 AM »
You need something like this
Offline braincube
« Reply #4 on: October 14, 2014, 09:58:33 AM »
Ha!
I meant - what measurements should I be testing? What values should I see?
I (generally) know how to use a multimeter..
KiefRichards
« Reply #5 on: October 14, 2014, 10:01:20 AM »
Ha!
Is there a component test in the manual for it?
Post a wiring diagram of the ignition system... Then we can walk you through it
« Reply #6 on: October 14, 2014, 01:14:47 PM »
measure the ignition and pulse coils with it.
« Last Edit: October 14, 2014, 01:16:28 PM by dave500 »
Offline zeech
« Reply #7 on: October 14, 2014, 02:06:11 PM »
CDIs could be fried. 650s can be a pain. I got rid of them all together, but I also completely rewired my bike.
« Reply #8 on: October 14, 2014, 06:28:21 PM »
Do you mean it is just flopping about? It should be held with 2 screws to the plate.
Offline SOHC
« Reply #9 on: October 14, 2014, 09:53:02 PM »
Curious How did u get rid of the CDI's?
Current:
1979 Honda CB650 (Hardtail Build)
1983 Suzuki GS850L (Fix and Minor Restore)
Old:
1989 Suzuki Katana 600
1978 Honda CB400T "Hawk"
1983 Honda VF750
Offline trueblue
« Reply #10 on: October 15, 2014, 06:23:33 AM »
Well technically they aren't CDI units, they are essentially pulse amplifiers. The ignition system on the 650s are little more than an electronic point system. Very basic in the world of electronic ignitions. If I remember correctly to test the pulser unit it is as simple as checking the resistance between the two wires that go to the unit.  If you have one pulser that is loose you have likely found your issue before you began.  They need to be held firm. There is no tolerance for movement with these parts. ;D
1979 CB650Z
Offline braincube
« Reply #11 on: October 15, 2014, 08:34:56 AM »
Alright - thanks a ton, guys.  These replies are all very helpful, particularly the stuff about the CDI and loose pulser generator. I'm gonna go in there tonight and check all of these things out, then report back ... wish me luck!
