Author Topic: Where does this O-Ring go? Rear Hub 1972 CB500  (Read 1342 times)
Offline jmelche2
  • 1974 CB550
« on: October 17, 2014, 09:40:55 AM »
Not sure if this O-ring goes on before or after the sprocket.  Looking at the parts diagram, it looks like the sprocket goes on first, then the o-ring.  Just want to make sure.
Thanks!
Re: Where does this O-Ring go? Rear Hub 1972 CB500
« Reply #1 on: October 17, 2014, 10:11:27 AM »
just have this scan..dont think it helps ???is there 2 o rings like nr 20...not shure this photo are a 500 or 550..
« Last Edit: October 17, 2014, 10:15:24 AM by strynboen »
Offline jmelche2
  • 1974 CB550
« Reply #2 on: October 17, 2014, 11:04:10 AM »
Thanks but your attachment is too small to read.  It is #22 in the photo I have attached.
« Reply #3 on: October 17, 2014, 12:18:57 PM »
think my are for 550..so dont use it anyvay
Offline jmelche2
  • 1974 CB550
« Reply #4 on: October 18, 2014, 03:03:33 AM »
Bump
Offline s7paul
« Reply #5 on: October 19, 2014, 12:29:51 AM »
The sprocket must sit flat against the hub, which it may not do if the O ring is underneath it.  I'm virtually 100% sure the O ring goes on after the sprocket, and acts as a seal between the sprocket and the plate (item 2 in your diagram).
Offline jmelche2
  • 1974 CB550
« Reply #6 on: October 19, 2014, 02:54:14 AM »
Agreed.  I found a photo on Sohoron's build thread where the o-ring goes on after the sprocket.
Thanks!
