Author Topic: Bouncy highway ride  (Read 2047 times)
Offline gregripko
Bouncy highway ride
« on: November 12, 2014, 01:54:36 PM »
%90 of my riding occurs on surface streets and for the most part it's a smooth ride... However there's a stretch of highway that I sometimes take that has rough uneven slabs that create a head shaking and unpleasant ride. The effects of the bounce can be felt from the front end for the most part. Any remedies? My rear shocks are at their greatest/loosest position. Not sure about fork oil but pretty sure I used Dexton VI ATF fluid. I weigh about 143lbs
« Last Edit: November 12, 2014, 02:00:14 PM by gregripko »
Re: Bouncy highway ride
« Reply #1 on: November 12, 2014, 02:10:36 PM »
Fork oil refresh/ or change wt.
progressive fork springs
be sure you have a fender or fork brace
check swingarm for play.
add a steering dampener.
Offline oldhatt45
  • The person called in at the last minute to share the blame is the...
  • Just an Old Guy that's gone to the Dogs
« Reply #2 on: November 12, 2014, 02:14:25 PM »
gregripko,
Are your Front and Rear Wheels aligned with each other????
If you have Hondaman's 750 book (assuming you have a 750) he talks about Alignment of the wheels.
Something else to look at in addition to what flybox1 has already said,
Charlie
« Reply #3 on: November 12, 2014, 05:28:28 PM »
The rule of thumb is "If you feel it in the front end, the problem is in the rear".
Bouncing after hitting bumps in the road indicates a lack of damping in the shocks..
Offline 750cafe
« Reply #4 on: November 12, 2014, 05:46:34 PM »
Have you ever greased the steering bearings and set the preload on those bearings?
Eric
Is there anything more fun than riding? They are between your legs and are quiet when you turn them off.
Offline goldarrow
  • one day, i'll be an
« Reply #5 on: November 12, 2014, 06:32:26 PM »
Or just simply get used to SoCal freeways where concrete is used
CB550 K0
Offline gregripko
« Reply #6 on: November 12, 2014, 06:35:52 PM »
I replaced the steering bearings a while back to tapered.......cb550 btw
« Reply #7 on: November 12, 2014, 06:53:44 PM »
Stock, worn-out rear shocks?
Offline gregripko
« Reply #8 on: November 12, 2014, 07:00:21 PM »
I have about 36,000 miles on the bike....not sure if they're stock rear springs....is there an indicator?
« Reply #9 on: November 12, 2014, 07:26:41 PM »
I think you are feeling the indicator, time for some new shocks.  And not cheapo eBay shocks, get some Hagons or Ikons.
Have you checked the swing arm bushings?
Offline bjbuchanan
« Reply #10 on: November 12, 2014, 08:42:48 PM »
If you can't tell then they are probably worn out junk
Offline gregripko
« Reply #11 on: November 12, 2014, 09:06:23 PM »
I have my shocks set to this position
« Last Edit: November 12, 2014, 09:19:48 PM by gregripko »
Offline bjbuchanan
« Reply #12 on: November 13, 2014, 08:40:23 AM »
That is the softest position on there. You can tweak it higher but it probably won't help anything, just be stiffer on bumps.
If there are no identifying marks on the shocks then they are probably stock. These shocks, by reputation, sucked @ss from the factory. I have never seen an aftermarket supplier that doesn't brand their stuff, its usually a big tip off. The stock shocks might have a little logo near the bottom clevis too.
Deal with it for now as long as it isn't unsafe feeling and get yourself some good shocks after a bit. You already seem to do right by the bike by the looks of that Motogp pipe  ;D
Offline Maurice
« Reply #13 on: November 13, 2014, 09:15:17 AM »
Check tire balance, whether you've thrown a weight or tire may have worn unevenly.
Offline Muckinfuss
  • "I plan to live forever.....or die trying."
« Reply #14 on: November 13, 2014, 12:17:41 PM »
Springs and spring rate, whether front or rear have to do with getting the suspension back to 'static' compression while navigating road surfaces.  When sitting on the bike, the compression of the front or rear is controlled by the springs.  Too much static compression gives a soft, wallowing ride prone to bottoming out; too little ....you get an iron butt.
Pogo-ing is a failure in the dampening of the shock/fork.  Given your weight, the ATF should be ok in the forks.  However, put a 15 wt fork oil in and see if it improves anything.  ATF is about a 7 wt.  If it changes things for you...you're done for now.  If it doesn't .... then you're off to buy some new rear shocks.
1984 Sportster 1000cc XL
1988 Heritage Softail
1974 CB550
1989 Corvette
Offline gregripko
« Reply #15 on: November 13, 2014, 12:24:24 PM »
Thank you for all your responses.... This will def help me resolve the issue systematically rather than blind guessing.
