Author Topic: ARGH. Slightly bent advancer shaft & jumping 2/3 timing...  (Read 808 times)
Offline grumpy
  • ..... '73 750K3 .....
« on: November 10, 2014, 11:20:32 AM »
Dammit, I can't get my advancer shaft straight enough to for 2/3 timing to be steady.
Been like that since I got it. Tried many times to straighten it using a homemade runout gauge & rubber mallet. Can't get it close enough.  >:(
There must be a more elegant & effective method ??
Any good tricks?
Maybe switch to a 20lb sledge or a 6' extension/pry bar?
« Last Edit: November 10, 2014, 11:23:51 AM by grumpy »
Re: ARGH. Slightly bent advancer shaft & jumping 2/3 timing...
« Reply #1 on: November 10, 2014, 12:44:08 PM »
i just said ufck-it and bought a NOS one for $20  :P
no regrets, but it took a while for one to pop up on feebay.
« Reply #2 on: November 10, 2014, 01:11:59 PM »
Any good tricks?
I can't imagine that if it was messing up 2/3, that it wouldn't mess up 1/4 also?
A new one may be in your future. A new point plate may be also.  The good ones are "TEC" brand.
Offline grumpy
« Reply #3 on: November 11, 2014, 09:41:04 AM »
not necessarily - 2/3 go first. can't recall exactly why. there's a Hondaman blurb on it somewhere...
the points plate is a new TEC so that's good
can't replace the shaft w/out splitting the case, no?
« Reply #4 on: November 11, 2014, 09:55:55 AM »
just double nut it and back it out.
6mm IIRC
...might be easier to get it straight if its out
« Last Edit: November 11, 2014, 09:57:29 AM by flybox1 »
« Reply #5 on: November 11, 2014, 10:03:32 AM »
Just run it by a machinist, or millwright, (with a dial indicator,and soft hammer), and bring a 6 pack
Felt pen mark the points plate if you remove it..
 Should be able to get it to.004 TIR or less.. Easily..
Offline grumpy
« Reply #6 on: November 11, 2014, 10:17:02 AM »
Really? It just unscrews??
Damn, yeah. Should be way easier to get it straight with it out.
I'm sure this is obvious but... right hand thread? (better to be sure than f it up)
« Reply #7 on: November 11, 2014, 10:18:34 AM »
Really easiest to straighten,  still in the crank..
« Reply #8 on: November 11, 2014, 10:34:58 AM »
Once you get it out, you'll probably see an old, compressed o-ring on it.  Get a new one on there  ;)
Unless someone knows size off-hand, you can mic the waist where it sits, and the OD of the shaft to get aprox o-ring size.
Offline grumpy
« Reply #9 on: November 11, 2014, 05:39:06 PM »
yeah, saw that o-ring on the fiche: 6x2.3
754:
my gauge doesn't work well with it on-bike. no place to anchor it. figure if I might have a better shot with it on the bench...
