Author Topic: honda cb 500 worn transmission gears and worn gearshift forks identification.  (Read 581 times)
Offline kranta
  • honda cb 250RS 1981 CAFE & honda cb 500 four 1978.
so, how i can identification is transmission gears worn or gearshift forks worn with out plastig gauge or with out dial gauge?
i am asking this because i am going to look one motor which is in parts and i want to know how i can see is gears worn or forks worn.
-kranta
Offline strynboen
you can feal and see if the parts are vorn aut.
.are the parts raundet hvere they must be sharp 90degreed.(.and so on)..are there rubbed some martrial of the forks ..or are they bend..
have you problems...since take it apart.
..is it spring aut of 3 gear???
or saying ticcing saunds. or missing some gear.there are many problems and many vays to make it right..but ve need some info  to hit it right
i hate all this v-w.... vords
Offline kranta
actually i dont have motor apart. i am going to look one motor which one is SELL and i am going to look it, if i m going to MAYBE buy it.
 and i want to know where i know if transmissions gears are worn or if gearshift forks are worn and How i can identification if they are worn with out plastig gauge or dial gauge???
or can some one post photo where is showed worn transmission or gearshift forks?
Offline strynboen
try to seargh on      "  undercut gear"        there the most vorn aut gears photoes are
you can remove the sump pan and look for blued or burnt gouged looking shifter forks,look for rounded engagement dogs,look for missing teeth and pieces in the sump.
Offline kranta
ok, thanks ;D
