Author Topic: Correct routing for choke cable/wiring harness - CB550k  (Read 644 times)
Offline eigenvector
« on: February 07, 2015, 11:29:40 AM »
What is the correct side of the fork to route the choke cable?  The actual mechanism is on the left side of the handlebar and the choke lever on the carb is I think pretty dead center - maybe slightly to the right.
Should the cable route to the left of the stem, through the triangular space between the frame and steering stem?
That said, should the electrical cables route through the other side, on the right side of the stem between the frame and steering stem.
I'm trying to cram all that stuff back together now that I have a new wiring harness and what appears to be a working engine.  Everything was originally routed through the left side opening - that's pretty crowded.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
Re: Correct routing for choke cable/wiring harness - CB550k
« Reply #1 on: February 07, 2015, 11:47:51 AM »
the shop manual have routing of vire and kabels...it can be find here...
« Last Edit: February 07, 2015, 12:10:11 PM by strynboen »
Offline eigenvector
« Reply #2 on: February 07, 2015, 12:01:38 PM »
My apologies
Rob
1977 CB550K
1983 VF750S Sabre
