Author Topic: plug caps?  (Read 1221 times)
Offline stewonepot
plug caps?
« on: February 10, 2015, 08:43:39 AM »
Hi All,
I have decided to change the plug caps on my CB750f1 (German version)
I have sourced new caps on eBay with 5ohm value.
Is this OK
The value of my old caps ranged from 3ohm   to   10ohm              but here is the but   she ran very well.
PS i Also have new plugs installed.
Will these new caps make any difference?
Regards Stew
Re: plug caps?
« Reply #1 on: February 10, 2015, 08:57:49 AM »
A better spark is a good thing  ;D
(potentially) better fuel econ, easier starts, less emissions
Offline alacrity
  • Ride, Optimize, Repeat
Re: plug caps?
« Reply #2 on: February 10, 2015, 09:36:54 AM »
if your old plug caps are tested correectly and function correctly, the only benefit new ones will offer is that they might be prettier.
Offline Duanob
  • Bold Timer
  • Gotcha!
Re: plug caps?
« Reply #3 on: February 10, 2015, 10:05:09 AM »
I dunno the original caps and wires a just plain old at this point. I've never understood Honda's idea that plug wires are part of the coil and would never need replacing. On all of the older vehicles I've owned, replacing plugs, wires was just part of the annual tune up process. Replacing them can only make it better. I replaced my OEM coils with Dynas and replace the wires every two years just because I don't put nearly the miles on my old bikes as I would a daily driver. Makes me feel better.
And I think you mean 5000 OHMs? not 5 OHMs. Did you get NGK caps? They seem to be the best replacement for old Hondas.
1974 CB360T
1976 CB550K2 Resurrected
1976 CB550F2 Barn Find
1979 CX500 VG "HONDA-GUZZI"
2007 Moto Guzzi Breva 750ie
2015 BMW F700GS
Another 1976 CB550K Cafe?
  __o
_- \_<,
Offline stewonepot
Re: plug caps?
« Reply #4 on: February 10, 2015, 10:15:56 AM »
Hi Duanob
Yes the plug caps i am after are NGK in black just for looks, It sounds tricky to change the HT leads.
And yes you are correct 5000ohms   Not to many zeros on my cheap meter.
Regards Stew
Offline Herr Supersport
Re: plug caps?
« Reply #5 on: February 10, 2015, 11:29:17 AM »
Steve
I assume your are using R-type sparks - myself cannot get others today - so you have one resistor in the cap and a second in the spark. Normally that works OK.
If your bike doesn't run well, you can remove the resistor from the plug cap and then put in a 5mm [diameter]/18mm [length] piece of alloy or copper instead.
The long type [XZ05F..] has the resistor towards the spark. Undo the brass-screw and erverything will fall out.
The short type [VD05F..] has the resisitor towards the wire. To open it you turn a weak-alloy tube with inner dia 2.8mm on the screw, move it right-left-right-left an pull the screw out. To reassemble, just press the screw with the two washers back in the body.
Greets, Daniel
Re: plug caps?
« Reply #6 on: February 12, 2015, 08:11:17 AM »
Your caps have screw threads at the end that bites into the copper.  It is a good practice to just snip an small piece off the end of wire to assure you are connecting to cleaner copper.
Offline stewonepot
Re: plug caps?
« Reply #7 on: February 12, 2015, 08:52:51 AM »
Yes Bobby that is what I will do when they arrive.
Cheers Stew
Online PeWe
Re: plug caps?
« Reply #8 on: February 12, 2015, 10:33:20 AM »
NGK D8EA and Denso X24ES-U are non-resistor plugs. Both available.
I need another box when my carb tuning session last year has consumed at least 24 plugs.... can not read a fouled plug...
