Author Topic: Help Honda twin leading shoe speedo cable  (Read 1410 times)
Offline craig
« on: February 22, 2015, 04:27:04 AM »
Help Honda twin leading shoe . how is the speedo cable retained in this hub which I think iwas fitted to the cb350? \
Offline Dino
    • HackAWeek
Re: Help Honda twin leading shoe speedo cable
« Reply #1 on: February 22, 2015, 05:17:10 AM »
I don't think that's from a CB350. They had a 6mm bolt that held in the speedo cable. I did some Google image searching and the closest thing I came up with was from a Suzuki TS250. The speedo cable has a threaded collar that goes in that hole. Take a look in there and see if it has threads.
If it ain't broke, don't fix it!
« Reply #2 on: February 22, 2015, 06:18:03 AM »
I think I see a circlip on the inner edge of that speedo cable hole and that may be what retains the cable.
Offline craig
« Reply #3 on: February 22, 2015, 06:33:52 AM »
will look into the Suzuki , does look bigger than the cb350 item , 3 holes in other side not 5 as ive seen on Honda \
Offline craig
« Reply #4 on: February 23, 2015, 02:20:57 AM »
thanks think ive found it T500 Suzuki 8 inch
« Reply #5 on: February 23, 2015, 10:35:49 AM »
Lot's of road race guys use the T500 hub when doing Vintage racing CB350's,I've been told on hondatwins.net that they work real good.
Offline craig
« Reply #6 on: March 05, 2015, 04:40:47 AM »
dam still not 100% sure on this hub , got the speedo cable but its a screw in attachment at the hub end , anyone know if Suzuki did a circlip attachment , also drive takes a square ended cable (like some british bikes) the cable I have for a t500 has the forked end like the Honda tacho cable .
« Reply #7 on: March 05, 2015, 11:08:03 AM »
What if you remove the front wheel and clean out the inside of the front brake backing plate & hub to look for any i.d. marks in the castings ?
Offline craig
« Reply #8 on: March 06, 2015, 12:44:42 AM »
i have done this and stripped the hub , there is no name etc to be found , i can/will make a drive cable but would still like to id this hub , thankyou for your help
Offline Oldtech
  • Motorcycle tech: old, cranky and retired
« Reply #9 on: March 06, 2015, 05:19:12 AM »
A lot of vintage racers have reported cracks in the webs inside the hub on T500 front drums. Check yours carefully before using. I've used the T500, XS650 and GT750 TLS drums on race bikes. My favourite is the Yamaha piece.
Offline craig
« Reply #10 on: March 08, 2015, 12:56:07 AM »
thanks its looking like this could be Yamaha with some modification \
Offline krusty
« Reply #11 on: March 08, 2015, 01:50:48 AM »
Looks like a Yamaha hub, just a guess but maybe first model RD250/350.  Yamaha inner cables have a square drive and the outer cable fitting to the hub also had an oring to keep moisture out of the speedo drive gear. They are retained by and internal wire circlip. Yamaha often cast the model code inside the hub and plate, and sometimes the 3 crossed tuning forks logo.
Honda
1976 CB750F1
1978 CB750F2
1972 CB350F
1961 C100 Cub
1962 C100 Cub
1959 C76
1963 C92
1964 C95
Suzuki
1963 M15D 50cc
1961 250TA Colleda
Yamaha
1977 DT175E x 2
1978 DT125E
1979 DT125F
1976 DT250E
1978 DT250G
1984 FJ1100
1990 FJ1200
Offline brewsky
« Reply #12 on: March 08, 2015, 04:01:43 AM »
Not a T500, They have an extra "spoke hole" between each spoke.
66 CA77
78 550K
78 CB750K
02 FZ1
09 GL 1800
Offline craig
« Reply #13 on: March 12, 2015, 02:05:14 AM »
thanks for all your help , turned out to be off a Kawasaki , time to see if it still runs
