Author Topic: Valve cover bolts/screws: what do you like?  (Read 1417 times)
Offline JBMorse
    • Travel Blog
« on: March 15, 2015, 01:47:58 PM »
Another question that came up while doing a top end rebuild has to do with the 6mm valve cover screws. I ruined a couple of them getting them out (yes I have JIS screwdriver, these were very stuck). I do have extras of these, but I was considering replacing all of them with new.
For the lower part of the engine, you can get kits of nice socket head SS screws:
I'm not sure I want these for the top of the engine. Has anyone seen kits for the valve cover bolts with something else? Maybe SS cap screws like these:
The pan head 6mm machine screws at hardware stores have much bigger heads than the Honda screws and I think they'd look a little odd. There's also the question of whether to replace them with all the same or use hex bolts where they were originally and something else in place of the JIS screws.
What have you all used for this?
1971 CB500K
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
Re: Valve cover bolts/screws: what do you like?
« Reply #1 on: March 15, 2015, 04:32:01 PM »
I have the round socket heads like in the first photo. I think button heads would be too wide.
--Evan
1975 CB750K "Rhonda"
« Reply #2 on: March 15, 2015, 04:51:36 PM »
Agreed.   Too wide.
I have the socket heads too.  Love them.
Offline JBMorse
    • Travel Blog
« Reply #3 on: March 15, 2015, 06:55:21 PM »
I compared Hillman brand button head to the original pan head screw and it was the same head diameter. I might just go with those, but I see no kits of them anywhere so I would be paying for them individually, which would add up quickly.
I've seen some pictures of socket head screws for the valve cover and they do look pretty nice. I'll have to think about which way to go.
1971 CB500K
Offline slikwilli420
  • Master of Disaster
« Reply #4 on: March 15, 2015, 06:59:48 PM »
Try allensfasteners.com for any fasteners. They must buy them by the truckload because they are substantially cheaper than anywhere else.
