Author Topic: 1976 cb750f broken fins on head and jugs.  (Read 2449 times)
Offline DrunknTso
« on: April 07, 2015, 07:35:23 PM »
Is the jug on 75 and 76 cb750f
interchangable? Also head?
Offline flyboy245
Re: 1976 cb750f broken fins on head and jugs.
« Reply #1 on: April 07, 2015, 07:35:51 PM »
Yep. I believe they changed in 77
« Reply #2 on: April 07, 2015, 09:42:41 PM »
Yep same engine as basically is the 77 and 78 K.
Offline DrunknTso
« Reply #3 on: April 13, 2015, 08:37:11 PM »
Thanks guys. So I should look for 77-78 k jug/head as replacement? Or...? pardon my typing I have a gnarly TBI
Online Don R
« Reply #4 on: April 16, 2015, 09:44:17 PM »
No, 75 & 76 are the same. 77 & 78 are different.
« Reply #5 on: April 16, 2015, 09:58:25 PM »
Pretty sure I have them.  What is the number on your head?
« Reply #6 on: April 16, 2015, 11:56:50 PM »
Don, 75-76F have the 392 head , same as the 77-78K, you're mixing up the 77-78 F & K models , its the 77-78 F models that have the different head and jugs... :D ;)
« Reply #7 on: April 17, 2015, 12:51:05 PM »
So yes, the 75F, 76F, 77K, 78K can all be used. The 78K head if complete will have different valve collars and the valves will differ only in the cut for the collars. The 78K head if complete will have the stronger springs found in the 77F and 78F. If the 78K head is bare you can use any of the valves and collars other than the 77F and 78F.
« Reply #8 on: April 17, 2015, 03:10:50 PM »
Jerry knows his head!
« Reply #9 on: April 18, 2015, 06:24:08 PM »
Yes, he does!
