Author Topic: Master cylinder rebuild question...  (Read 2248 times)
Offline j2dawson
« on: April 19, 2015, 03:47:30 PM »
I've got the MC off the bike and have ordered the kit, but I can't get past the first step! I can't get that damn clip that holds the rubber boot on, out of it. It's pretty well corroded and I can't get anything under the end of the clip to lift it out. I can't even figure out how to destroy it so it will come out.
Any suggestions?
Thanks,
Jim
Offline Johnie
Re: Master cylinder rebuild question...
« Reply #1 on: April 19, 2015, 04:23:50 PM »
First tear that rubber out of there best you can. Then I leave it sit overnight with some PB Blaster. Then I use a small mechanics pick to get the clip out. The clip is the easy part...wait until you try to get the cir-clip out.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
Offline j2dawson
« Reply #2 on: April 19, 2015, 05:11:38 PM »
Thanks for the help. I tore the rubber out and have it soaking now. I'll give it another try tomorrow. I expected the circ-clip to be a bear but didn't anticipate this much trouble with this clip.
Offline Johnie
« Reply #3 on: April 19, 2015, 05:26:37 PM »
I hear you. They can be buggers too. Good luck and let us know how you come out.
Oshkosh, WI  USA
Offline j2dawson
« Reply #4 on: April 19, 2015, 06:33:30 PM »
Thanks for all the help, I got it all apart. Now just waiting for the kit.
Offline Johnie
« Reply #5 on: April 19, 2015, 06:59:33 PM »
By the way...welcome to the board! :)
Oshkosh, WI  USA
Offline j2dawson
« Reply #6 on: April 19, 2015, 08:23:59 PM »
Thank you very much!
Offline Johnie
« Reply #7 on: April 20, 2015, 07:17:56 PM »
Did you order a Honda kit or aftermarket?
Oshkosh, WI  USA
Offline j2dawson
« Reply #8 on: April 21, 2015, 03:23:50 AM »
Oh no, I feel a warning coming on - I think it's a K&L kit. Is that bad?
« Reply #9 on: April 21, 2015, 03:55:07 AM »
I used aftermarket kit for both my MC rebuilds, you will be fine.
Offline j2dawson
« Reply #10 on: April 21, 2015, 03:59:28 AM »
Whew, thanks!
Offline Johnie
« Reply #11 on: April 21, 2015, 05:08:07 PM »
You will have to insert the rubber seal over the piston when you get it.
Oshkosh, WI  USA
