Author Topic: Bleed Valve  (Read 823 times)
Offline Timindecaturga
Bleed Valve
« on: May 04, 2015, 04:50:14 PM »
Does this grey stuff been to come off or just drive the valve in with it on I'm a bit nervous that it seem like it's going to cross thread the caliper
Thanks
Re: Bleed Valve
« Reply #1 on: May 04, 2015, 06:12:43 PM »
...looks like pre-applied thread sealant...if your threads are good and you got the bleeder started straight, go a head and tighten it up
Offline DaveBarbier
Re: Bleed Valve
« Reply #2 on: May 04, 2015, 06:16:08 PM »
Mine's the same. It's just some sealant. Just be aware that it probably will bottom out with some threads showing. That's normal. No need to go nuts and crank on it.
1978 Honda CB550K
Re: Bleed Valve
« Reply #3 on: May 04, 2015, 06:19:52 PM »
Thanks all I thought they put it on as a seal but never hurts to double check
