Author Topic: clear tube fuel level test  (Read 5220 times)
  • I'm back
Re: clear tube fuel level test
« Reply #50 on: June 14, 2015, 12:20:02 PM »
Personally I wouldn't use guitar wire.
« Reply #51 on: June 14, 2015, 01:14:40 PM »
I got them out ...letting them soak in seafoam...steel wooled them and carb sprayed and guitar wireing them to make sure perfect...anything else?....tp make sure insides are spotless?
carb cleaner, steel wool, wire to poke the holes clean.  Scrub them.
Soaking them, does nothing.
Offline oldhatt45
« Reply #52 on: June 14, 2015, 03:20:33 PM »
screemn2,
I am by no means a carb expert.  But, from reading other threads and hearing about problems, I have kind of an off the wall question for you.
Have you checked for Air leaks at the carb to engine boots?
One of the other guys can give you more info on how to do this, but I believe you fire her up and spray some carb cleaner around the connections.
In Hondaman's book I recall reading something about doing this and that the idle will change if there is a leak.
This is just a thought and probably way out in left field, but seemed like at least something that might help rule out another problem, since you have had the carbs on and off a couple of times.
Hope this helps,
Charlie
Offline screemn2
« Reply #53 on: June 14, 2015, 05:02:13 PM »
Thanks oldhatt....got brand new intake gaskets in place and brand new carb to intake boots...did use propane to look for leaks didnt find any...im really hoping that cleaning and clearing out pilot jets did somthing ..waiting for them dumb gaskets to shrink back down to reinstall carbs and find out....got my fingers crossed :-\
Offline Pecantree
« Reply #54 on: June 15, 2015, 08:25:45 PM »
A quick way to shrink the bowl gaskets is to simmer them in water. I forget how long. maybe 10 minutes.
DON'T do this when your wife is home.
Good luck
Steve
Offline screemn2
« Reply #55 on: June 16, 2015, 12:32:45 PM »
Hey thanks pecantree...got them shrunk up now ..but will remember that for next time... :)
Offline jonda500
« Reply #56 on: June 16, 2015, 10:06:55 PM »
Good luck
Steve
This is an excellent tip - thanks Steve!
A starter clutch thread:
Offline greenjeans
  • 1972 CB750K2
« Reply #57 on: June 17, 2015, 08:02:35 AM »
Get no-swell gaskets.   The ones that expand can, and will.  Then there is a chance that your floats will hang on them.
Been through that.
« Reply #58 on: June 17, 2015, 08:22:39 AM »
Been through that.
+1
Viton is the material which will not swell.  if it doesnt say Viton, find another seller.
