Author Topic: Carby balance tube???? on 750 K2  (Read 1399 times)
Offline k2 sohc
« on: June 21, 2015, 03:23:31 AM »
what does this balance tube do, that connects carby 1 & 2 together and carby 3 & 4 together. A month ago I replaced the tube between carby 3 & 4 because the tube had perished away over the years unknown to me and the bike has been running well. I only spotted this when I was replacing new carby fuel lines. On the first ride I did since all the replacements I had travelled no more than 30 miles when I lost all power in #4 cylinder. All other 3 header pipes were hot as, #4 header pipe was warm. Road side inspection showed good spark on #4 plug and was very wet. On several attempts #4 cylinder did not come to life. On pulling down the motor #4 piston had a hole in it. As the bike has been running very well over all these years, could the replacement balance tube cause #4 carby to run very lean? causing piston to melt a hole in it.
thanks Alex
Australia
750 K2 had since new
BMW R90/6 outfit had since new
Triumph T140v Bonneville since new
BSA A10 Goldflash
Offline HotCarl73
Re: Carby balance tube???? on 750 K2
« Reply #1 on: June 21, 2015, 10:15:18 AM »
I think the long tubes between 2 and 3 are just the vent to atmosphere and the small tubes between are to connect the vent to the 1 and 4 carbs. I'm no carb expert but I think if those tubes weren't even there, all the carbs would be vented and work fine. If that vent was plugged up on any carb, that would cause problems because air couldn't get into the bowl to replace the falling fuel level and there would be a vacuum making the carb not deliver fuel. It's like when you get no fuel through the petcock if your gas tank vent is plugged or not working. I'm just guessing, wait for somebody smarter than me to chime in.
« Last Edit: June 21, 2015, 10:17:44 AM by HotCarl73 »
1973 Honda CB750 Flake Sunrise Orange
1974 Honda CB750 Flake Sunrise Orange (In Pieces)
1995 Ural Tourist
2005 Honda 919
Offline k2 sohc
« Reply #2 on: June 27, 2015, 01:50:59 AM »
thanks hotcarl.
I will see what other reply's come back with
alex
BSA A10 Goldflash
Offline dusterdude
« Reply #3 on: June 27, 2015, 04:21:38 AM »
Im guessing its a vacuum balance tube of some sort
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline k2 sohc
« Reply #4 on: July 23, 2015, 05:26:06 AM »
thanks fellows there was nothing in the oil pan to show anything, just fine aluminium chards.
the barrel will get away with a hone. so it back to rebuilding the beast
thanks for the replies
BSA A10 Goldflash
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #5 on: July 23, 2015, 05:53:54 AM »
Those tubes are the bowl vents. The short ones that connect 1-2 and 3-4 make the air vents on 2 and 3 connect to the 1 and 4 carbs respectively.
If they were plugged, the bowls wouldn't fill with gas as quickly as needed.
--Evan
1975 CB750K "Rhonda"
