Author Topic: 1972 Honda CB 500  (Read 6661 times)
Offline honder
Re: 1972 Honda CB 500
« Reply #25 on: June 06, 2016, 08:59:39 AM »
I did check the piston rings for end gap clearance as well and they both came in at tighter than .020 "'s
Offline honder
« Reply #26 on: June 07, 2016, 12:08:07 PM »
Would anyone know how much clearance there is between the pistons at tdc and the valves when they are open?
I have the face of the cylinder head machined and am now wondering if there is a possibility too much was taken off and the clearance between the pistons and valves now taken down to something that'll allow contact to occur.
Offline honder
« Reply #27 on: June 08, 2016, 04:15:49 AM »
Ok great, thanks Cal
Offline honder
« Reply #28 on: February 18, 2017, 12:46:00 PM »
Tank Painted
« Last Edit: February 18, 2017, 01:03:51 PM by honder »
Offline honder
« Reply #29 on: February 18, 2017, 12:48:32 PM »
brake light installed
Offline honder
« Reply #30 on: February 18, 2017, 12:50:18 PM »
Brake Light
Offline honder
« Reply #31 on: February 18, 2017, 12:51:35 PM »
Carbs installed
Offline honder
« Reply #32 on: February 18, 2017, 01:03:09 PM »
So it seems I have hit a wall. I had the carbs rebuilt and cleaned and jetted for pod filters and the mac 4 into 1 exhaust.
When I installed the carbs I could get the engine to idle with the throttle partially opened, but wouldn't continue running with  it closed even after a few minutes warming up. With the throttle opened, the engine would hunt, the rpm surging then falling back to the point where the engine would almost die. I suspected it was running lean, so I just upped the pilot jets one size
(from 40 to 42). I tried to start without the pod filters on with the bigger pilot jets and it ran well. Good throttle response, though the rpm would stick around 4000 even when the throttle was returned to idle (which I am guessing is indicating a lean running situation in the mid throttle range), with only the application of choke bringing it back down. I began installing the pod filters as the engine idled and it began to idle progressively worse with each pod installed, finally stopping altogether once the fourth pod was in place.
Anyone else ran into this situation or have any ideas as to where to start troubleshooting?
« Last Edit: February 18, 2017, 01:05:29 PM by honder »
Offline firebane
« Reply #33 on: February 18, 2017, 03:48:50 PM »
Geez seems to be a lot of us Cow Town folk on here.
Offline honder
« Reply #34 on: February 18, 2017, 07:41:57 PM »
Ok, thanks Cal. I have some larger main jets coming, so I'll try those in there, but I'll also have a look for leaks and put a new set of seals and rubbers in.
Offline honder
« Reply #35 on: February 18, 2017, 07:43:38 PM »
the idle screw is out 3/4 of a turn currently and the needle is on the 5th slot.
And yes, there seems to be lots of us Calgary folk here.
Offline honder
« Reply #36 on: February 20, 2017, 09:12:38 PM »
So it looks like I have the idle sorted out. There were two things going on. I upped the pilot jets to 42 from 40 and after reinstalling the carbs back on the bike I decided to do a quick test run with no pod filters. Ran well, but was slow to return to idle from about 4000rpm on. As I installed the pod filters with the engine idling the idle became progressively lower to the point where the engine died with all four installed. I had them oiled and sitting in the garage where the temp is around 0, so I took a blowdryer to them to remove the excess oil, and that solved the idle issue, possibly in conjunction with the upped pilot jets.
Now that it will idle, I'll do some plug chops to see how the plugs are looking.
Since it has been idling reliably I have noticed a tapping noise that is more prominent on the left side of the engine than the right. I double checked the cam chain and the valve clearances and everything checks out there. I am at a loss for what is normal engine operating sounds and what is a sign of trouble as the bike hadn't ran for a number of years prior to me buying it, so I really have no baseline on which to draw any conclusions.
I'll put a link to a video with the engine noise when I get it uploaded
Offline honder
« Reply #37 on: February 23, 2017, 08:59:00 AM »
Here is the 500 idling. I pressed a screwdriver against the engine in various spots and it seems like the tapping is more prominent near the #2 exhaust on the cylinder head cover. I have double checked the valve clearances and the cam chain tensioner as well as installing new exhaust crush gaskets. Clicking is still there however it may be a tad quieter than it was before. Anyone have a better idea of whether this is normal engine noise or perhaps something that should be looked at a tad closer?
Offline honder
« Reply #38 on: February 23, 2017, 09:48:23 AM »
Changed the setting on the video, should be open now. I have the exhaust bolts cinched down, but I'll try torquing them a bit more.
Offline honder
« Reply #39 on: February 23, 2017, 10:01:56 AM »
No, just bench synced as of yet by harisuluv. I've yet to vacuum sync, but I'll do that next and let you know what comes of it.
Offline honder
« Reply #40 on: April 28, 2017, 05:46:33 PM »
Been busy the past while with work but have managed to get a few things done. I think I have narrowed down the tapping coming from the left side near the head to the rocker arm shafts. This an educated guess, though I watched a video of a guy with a 500 of the same vintage who replaced the two rocker arm shafts with the single rocker arm shaft that was used on the later model 550's and added a grub screw to hold it in place and prevent it from rotating around. I had spare rocker arms and shafts so I am going to try poly coating them to tighten up the clearances and provide a teflon buffer between the shafts and the cylinder head cover. I'll keep you all updated when they are installed.
I have been trying to wade my way through electrical stuff now. I have a new wiring harness from sparck moto that I have installed, and a regulator/rectifier from Ricks. I hooked everything according to the sparck moto and Ricks directions and have everything working though the battery isn't charging. (No increase in voltage measured at the battery as the rpm is increased) I've gone through the field coil and stator and measured the resistance and both are showing within spec. If I disconnect the white and green wires from the regulator to the field coil it shows voltage coming from the regulator, though as soon as the wires are reconnected, there is no voltage. Is this normal? I thought there may be a short in the field coil, so I tried a test on a spare field coil I have with the same results. I have also tried holding a wrench close to the generator cover with the power on with no noticeable magnetic field that I can see. Anyone have thoughts as to where to go from here?
