Author Topic: How can 750 roundtops run this rich..? ?  (Read 2939 times)
« on: August 28, 2015, 07:51:02 PM »
I am stumped on this one.. Had lots of 750,s..never had this.
Roundtops..been off and cleaned. A few times..
 Needle clip moved 2 notches leaner..  First or 2nd notch from fat end.
 Stock 105 jets not been able confirm, but a. 0463 drill bit will not enter..(approx 1.2 mm).
 Stock numbered pilot,#42 or #40.. The size listed in manuals is what it is.
 Idle screws 7/8 turn out.
 Finally today I pulled the breadbox filter off,  ran slightly better and cleaner.
 But...
 It still has visible black smoke coming out of the 4-2 pipes.
 If someone told me you could make one run that rich..with those parts, a month ago,  I would not have believed them.
 How is this even possible???. And what is left to do to make it leaner... I hit the wall here.. Can't think of anything else.
 Any ideas..?
Offline goldarrow
  • one day, i'll be an
Re: How can 750 roundtops run this rich..? ?
« Reply #1 on: August 28, 2015, 07:55:24 PM »
Sometimes the carbs are cursed...try different sets of carbs?
CB550 K0
Offline BPellerine
« Reply #2 on: August 28, 2015, 08:22:08 PM »
they begin with the letter w,haha bill
1978 CB 750K ard and webers
another anfob
DH
« Reply #3 on: August 28, 2015, 09:06:03 PM »
. My k5 did that. New needles and needle jets cured it. IIRC, Honda sold them in sets. They wore thinner.
Needle is constantly moving thru jet with each movement of throttle. Sometimes jet wears out.
Only way I found out was to try them. Just my experience...
Gotta add that they were replaced as last resort, everything else was vverified correct.
« Last Edit: August 28, 2015, 09:21:16 PM by DH »
« Reply #4 on: August 28, 2015, 09:10:31 PM »
 Float levels? My F1 had it all, drilled jets and screwey float valves bent up tabs etc. I was shocked how much high float levels richened the fuel mix.
« Reply #5 on: August 28, 2015, 11:47:59 PM »
+1...high mileage carbs need new needles and needle jets...might be easier to just find low mileage carbs
in my experience, it only really affects the transition from idle to part throttle
Offline Henning
« Reply #6 on: August 29, 2015, 01:47:49 AM »
The idle screw - makes a huge difference to the mixture, in my experience. Ignore the manual and turn it out to say 1 1/4 or more and see if it helps.
On mine ('71) the manual says 1 turn out and I'm at 1 3/8 and need to go further out. Otherwise stock exhaust, intake etc., needle middle position, new Keihin 115 mains and 40 idle jets.
71 or thereabouts 750 K1 - this one should have been put down
« Reply #7 on: August 29, 2015, 08:26:19 AM »
Okay reading hondamans book, he says turning in makes leaner..
 If this. Don't have this part correct, then I would be going opposite.
Offline BPellerine
« Reply #8 on: August 29, 2015, 09:14:26 AM »
needles and jets def worth a try.bill
another anfob
« Reply #9 on: August 29, 2015, 09:55:33 AM »
Made some progress,  pulled the breadbox filter, it helped.
Changed the car fuel filter this morning, it appears to be letting fines thru.
I have been thinking that now my tank is mostly clean, no new debris getting to filter. But filter was still letting thru some powdery grit that could still be causing float jets to leak.
 Will know in a few miles.
 I have a rough set of cards,  if I can find them,  I swap the brass or at least float needles, or I have at least one set of 72 carbs that were stored clean..
« Last Edit: August 29, 2015, 03:26:19 PM by 754 »
Offline BPellerine
« Reply #10 on: August 29, 2015, 03:05:25 PM »
was it still leaking fuel,or just running rich?I hated my pd carbs spent lots on them and still were not right,they were very dirty when I got them.bill
another anfob
« Reply #11 on: August 29, 2015, 03:27:40 PM »
Hard to see but puffing black smoke at idle..
Offline Spanner 1
« Reply #12 on: August 29, 2015, 03:43:44 PM »
+1 on float levels wrong ( fuel level too high ). BTW, on screw top carbs, the air screw is 'in' for richer idle air mix., the opposite of what you posted above  ;)
« Reply #13 on: August 29, 2015, 06:07:22 PM »
Slides installed backwards? (Never done it myself, but I know it has been done; just don't remember the result.)
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #14 on: August 31, 2015, 08:48:02 AM »
Roundtop carbs, idle screw in for more rich, out for lean.
--Evan
1975 CB750K "Rhonda"
Offline ofreen
« Reply #15 on: August 31, 2015, 09:29:36 AM »
Frank, are those needle jet sets stock or are they aftermarket (Keysters). I tried Keysters years ago and they were hopelessly rich no matter where the clip was set.
Greg
'75 CB750F
« Reply #16 on: August 31, 2015, 09:35:45 AM »
Not sure now, I think original. Bike has 33K miles on it. Looking for my other cars just going to swap them.. Are you back now Greg?
« Reply #17 on: August 31, 2015, 02:54:07 PM »
Just put a set of 657A on the bike.. It had a 657B rack on it.
 4 is touring gas thru the float, took it off cleaned it up, forgot to check height.. Still leaked. So off again, will measure float. Checked, it has a Keihin 2.0 seat.
Offline rotortiller
« Reply #18 on: August 31, 2015, 04:20:37 PM »
A buddy of mine had a similar issue and not saying this is your issue. Turned out someone drilled the emulsion holes in the jet holders.
Offline ofreen
« Reply #19 on: August 31, 2015, 08:26:01 PM »
I got back last night.  I looked at my records and see I replaced the first needle jet sets at 41,000 miles.  I remember fuel mileage started noticeably dropping at around 35,000 miles. By the time 41K rolled around plugs were fouling and mileage was at about 30 MPG.  The choke wasn't needed no matter how cold the ambient temperature was and the exhaust was eye watering.  Then I got hip to what was going on and replaced the needle jet sets and everything went back to normal.  So if yours are original I'd expect to see some wear at 33K but not enough to cause what you are seeing.
Greg
'75 CB750F
« Reply #20 on: September 01, 2015, 10:46:46 AM »
Greg will send you a pm..
 I put a new rack on,bit of floods ng, and float massaging, whole new bike now.
Ran over some rough road testing it, started runners ng rough in the midrange quite bad but cleared up mostly.. Will dropped mains and holder a clean up
 Got about 40 mpg. Some open road but not hiway speeds.
 Double the mileage it was getting and pretty nice idle..
 Whoo hook..
Offline BPellerine
« Reply #21 on: September 01, 2015, 11:39:49 AM »
California dreamin!!hahabill
another anfob
