Author Topic: Rust on exhaust - any tricks?  (Read 1256 times)
Offline Franky
« on: September 15, 2015, 04:40:20 AM »
Hi guys
Discovered these patches of more-than-surface-rust... Does anyone have some tricks up their sleeves on how to remove them or at least keep it in check?
1974 Honda CB360T Stock
1974 Honda CB550 K0 Stock
1977 Honda CB550 K3 Cafe - never ending build :)
1988 Honda Dax ST50 Cafe
1997 Honda Benly 50S Stock
Check out my "Yamaha R6 fork on a CB550 made easy" thread:
http://forums.sohc4.net/index.php?topic=118983.0;all
Re: Rust on exhaust - any tricks?
« Reply #1 on: September 15, 2015, 06:27:14 AM »
Blue Magic, or any chrome polish, and 0000 Steel wool.
« Reply #2 on: September 15, 2015, 07:02:37 AM »
Aluminum foil and coca cola. Pour on the coke and rub the foil on it.  The rust may be coming from the inside out which is common, so at some point a repair is in order.
Offline Franky
« Reply #3 on: September 16, 2015, 10:22:52 AM »
I did use some chrome polish for the more superficial rust, and it did the job. The patches on the photo go a bit deeper and can't be romoved with the above.
I thought about a dremel with a soft-ish tip and then applying some heat-resistant paint... Good idea?
Sendt fra min TF300T med Tapatalk
« Reply #4 on: September 16, 2015, 11:01:25 AM »
 Worth a try, anything to seal it up and buy some time.
Offline jeffg
« Reply #5 on: September 16, 2015, 01:06:57 PM »
I just cleaned my bike, all the rust came off.
it was only about 2.5 years that it was let go, so the rust was not that bad.
I used vinegar, and also toilet bowel cleaner, & steal wool; learned about it here.
have to counter the acid or you'll re-rust quickly.
It worked great!   :D
Offline przjohn
« Reply #6 on: September 16, 2015, 02:54:34 PM »
Looks like surface rust from below that no one will see. Wouldn't give a care. Would be interested to see if you used a method that worked and posted a pic though, please.
