Author Topic: Motorcycle Starting issue  (Read 3483 times)
Offline jetthugo
« on: September 16, 2015, 11:56:11 AM »
Im new to the riding community so Im still learning terminology and the mechanics of a motorcycle. My newly purchased 1973 Honda CB350F usually runs well, but at times won't turn over as seen in this video. I rode it two days ago for about a good hour but did not attach my trickle charger after parking it in the garage. But would the battery really be low after a day and a half? It's charging right now, but does it sound like something else could be wrong? Thanks for everyones help and solutions.
Here is the link to the video
Offline Mantree
Re: Motorcycle Starting issue
« Reply #1 on: September 16, 2015, 12:22:15 PM »
I didn't see you use the choke I'd there a strong gas smell?
Sent from my SM-G900V using Tapatalk
Offline jetthugo
« Reply #2 on: September 16, 2015, 12:36:03 PM »
Thanks for replying Mantree. I trimmed the video so it didn't show me messing with the choke on this, but yes I had it open but still no go.
There is an abnormal gas smell coming out of the bike.
Offline jetthugo
« Reply #3 on: September 16, 2015, 01:11:03 PM »
Thanks for the reply calj737.  I'll look into these two possibilities. I just rode it no problem two days ago, but since last week it seems to run whenever she wants to.
Offline Mantree
« Reply #4 on: September 16, 2015, 01:22:33 PM »
Might be spark too check plug condition that will give you a good starting point on if you are flooding or to lean.  Wet is flooded carbon is weak spark or rich. White is lean golden brown is spot on.  Clean or replace plugs and set gap. It is 73 so it has points pull the right side cover and look for scorching then check the connections at the coil as well as condition of the coil.
Sent from my ME302KL using Tapatalk
Offline jetthugo
« Reply #5 on: September 16, 2015, 02:11:40 PM »
Thanks Mantree. I'll check out the spark plugs and get back to you on that later today. Thanks for the tip!
Offline jetthugo
« Reply #6 on: September 16, 2015, 05:09:09 PM »
Here is what one of the plugs looks like. The second one looked the same. Replaced them with new ones and the bike still won't start. What do you think the new issue might be? I'm researching and someone said the engine might be running too rich. If this is the case, how do I fix this problem?
« Last Edit: September 16, 2015, 06:04:07 PM by jetthugo »
« Reply #7 on: September 16, 2015, 06:15:08 PM »
First off, check battery voltage after you fully charge the battery, should be 13+ volts.
Secondly, from the looks of your plug, carbs appear to be set super rich (too much fuel).
When was the last time the carbs were rebuilt? May have wrong size jets.
Offline jetthugo
« Reply #8 on: September 16, 2015, 06:42:00 PM »
Thanks for your reply Stev-o. I'll let it charge overnight and get back to you on that battery tomorrow.
I purchased the bike two months ago and I'm completely unaware of the last time the carbs were rebuilt. Is that the same thing as "rejetting the carbs"?
« Reply #9 on: September 16, 2015, 07:08:44 PM »
From the way the battery spins the motor, you don't have a battery problem. Do you have a voltmeter? What kind of charger are you using? You may create a battery problem by leaving the charger on it overnight. That spark-plug is horribly fouled.
« Reply #10 on: September 16, 2015, 07:10:57 PM »
What do the other two plugs look like?
Offline jetthugo
« Reply #11 on: September 16, 2015, 07:11:49 PM »
Thanks for the reply Scottly, I do have a voltmeter. I'll check the volts and get back to you. It's a trickle charger that the seller gave me when I purchased the bike. I'll get back to you on that reading. That second plug from the left looks identical.
« Reply #12 on: September 16, 2015, 07:23:27 PM »
Thanks for your reply Stev-o. I'll let it charge overnight and get back to you on that battery tomorrow. I
No.  Rebuilding is basically taking them all apart, cleaning and replacing necessary parts.
This may be the logical next step, then you'll know what you have and rejet if needed.
« Reply #13 on: September 16, 2015, 07:30:02 PM »
Might be as simple as a plugged air filter, or running the bike with the choke fully closed all the time. ;)
Offline jetthugo
« Reply #14 on: September 16, 2015, 07:46:24 PM »
I'm hoping it's nothing too big of an issue, I'll take a look at the air filter and get back to you. Thanks for the tip!
« Reply #15 on: September 16, 2015, 07:47:44 PM »
Offline Mantree
« Reply #16 on: September 17, 2015, 03:20:58 PM »
Pull the air filter and check it try starting the bike with the filter out of it starts replace the filter if if that don't fix it you may be jetted wrong
Offline jetthugo
« Reply #17 on: September 17, 2015, 03:25:44 PM »
When you say air filter, you mean this one right?
Update: took out the air filter and it looks good. Removed and tried to start the bike, still not starting.
« Last Edit: September 17, 2015, 03:53:16 PM by jetthugo »
Offline Mantree
« Reply #18 on: September 17, 2015, 06:22:08 PM »
Is there a strong gas smell?  Pull your plugs again after trying to start if they are wet check for spark you may have a bad coil or something in your points might be off.  I have even seen a loose wire stop a bike dead in its tracks.  The coil gets power from the kill switch on the handle bars then gets ground when the points arch to ground as he engine rotates.  That filter looks a little dirty can you see light through it clearly?
« Reply #19 on: September 17, 2015, 09:48:46 PM »
Did you replace all FOUR spark plugs?
Offline Mantree
« Reply #20 on: September 17, 2015, 10:00:35 PM »
He 350 is a twin it's just the 750 engine cut in half
Offline jetthugo
« Reply #21 on: September 17, 2015, 10:00:41 PM »
yea! All four were replaced. I think the issue might be with the ignition points. What do you think? Here's a video of it
Offline jetthugo
« Reply #22 on: September 17, 2015, 10:03:28 PM »
I know I said there was a gas smell in the previous posts, but I haven't smelled any since. The plugs still remain dry after I tried starting the bike. I can't see through the filter clearly, just purchased one online from 4into1.com
Thanks for the tips! I have a feeling something is off with the ignition points...
Offline Mantree
« Reply #23 on: September 17, 2015, 11:13:54 PM »
Do you have a timeing light? You can use it to make sure you have spark.  Is your petcock flowing Gas there should be a fairly strong smell fter cranking like that as you should be close to flooding it
Offline jetthugo
« Reply #24 on: September 17, 2015, 11:32:15 PM »
I just purchased a timing light today, unfortunately I have no clue where to connect it! Been looking to see how to use it. As for the gas, I'll pay extra attention tomorrow when I fire it up. Ill get back to you on that. Thanks Mantree
