Author Topic: 1970 Triumph Tiger 650  (Read 78339 times)
Offline grcamna2
Re: 1970 Triumph Tiger 650
« Reply #325 on: October 28, 2016, 10:17:17 PM »
PM,do a video when you start it  :)
75' CB400F/'bunch o' parts'
Offline Powderman
« Reply #326 on: October 29, 2016, 07:48:25 AM »
I plan to. There are others on other forums who don't think it will ever run. I'll do an"in your face" video, hopefully of a one kick start.
Offline grcamna2
« Reply #327 on: October 29, 2016, 08:08:17 AM »
PM,
I always wanted to ask about your avatar,what bike is that ?
Offline Powderman
« Reply #328 on: October 29, 2016, 08:45:51 AM »
PM,
It's a 1962 Sportster XLCH converted do XRTT using Sputhe heads. I have a build thread here somewhere, but can't seem to find it at the moment. 1327cc, 331lbs dry.
« Last Edit: October 29, 2016, 08:57:59 AM by Powderman »
Offline MoMo
  • Ride like you're invisible
« Reply #329 on: October 29, 2016, 09:07:00 AM »
Very nice HD PM.  Awesome indeed...Larry
Offline grcamna2
« Reply #330 on: October 29, 2016, 09:18:49 AM »
Someone hasn't been riding their Harley enough..  ::)
I like it better than a Buell  :)
« Last Edit: October 29, 2016, 09:21:31 AM by grcamna2 »
Offline Powderman
« Reply #331 on: October 29, 2016, 09:26:12 AM »
True dat.
True dat. I assume you are referring to the rotor coating.
Offline grcamna2
« Reply #332 on: October 29, 2016, 09:55:24 AM »
True dat.
Plus the tire is low from sitting?
Offline Powderman
« Reply #333 on: October 29, 2016, 11:41:45 AM »
True dat.
Tubeless tire on a modified tube rim. I was finally able to air it up, but for safety I will end up putting a tube in it.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #334 on: October 29, 2016, 12:10:34 PM »
Who are these nay-sayers? Whoever heard of a British bike refusing to start?
Humph. They know nothing. You show 'em, Powderman!
(And if it don't start first kick, just delete that video and post the one that shows it working properly  ;D)
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline grcamna2
« Reply #335 on: October 29, 2016, 12:11:58 PM »
What kind of rpm/powerband do you get out of that 'old school'  8) XLCH sportster engine ?
Offline Powderman
« Reply #336 on: October 29, 2016, 12:25:24 PM »
Great minds think alike. You didn't think I would foolishly post a video of me struggling to start a Triumph did you. Though I do have fond memories of myself and my deceased brother taking our bikes to the car wash and then after washing them, me on the Sportster and him on this Tiger, I would go sit on the curb. He would ask what I was doing not starting my bike. I would tell him I was taking a rest and would watch the next 10 minutes of him trying to start his wet Triumph. After working up a sweat and finally getting his running I would walk over to mine. Twist the throttle few times to prime the carb and kick it once to start it up.Pissed him off royally every time. Triumphs don't like being pressure washed.
Offline Powderman
« Reply #337 on: October 29, 2016, 12:35:31 PM »
Don't know, hasn't been fired up yet. It's a long story. But for 37 years, after building the basis of the bike, it sat in storage. When my engine builder built it he told me "I bought Pete's 63ci Sportster back and put his top end on your motor, taking it from 53ci to 63ci." So for the last 37 years I though it was 1032cc motor, up from 883. When I pulled it out of moth balls 5 years ago to ready it for a land speed record attempt after going to Bonneville a few times with a car I helped build and setting multiple world records, I realized I would have a hard time competing because my 1032 fit into a 1000-1350cc class and I would be at the bottom end of engine size. I ended up having to tear down this motor that had never been fired due to corrosion of the inside of the cases from sitting. When the new mechanic had it torn down he informed me that I did not have a 63ci engine. Needless to say I was extremely disappointed that my original builder, a friend, would have screwed me. New builder says " you didn't get screwed unless you think having 81ci is getting screwed. You have a 63ci top end, but he also gave you a 4-5/8" stroker kit in it." I was elated to know that for a few seconds while I figured in my head that indeed I now have a 1327cc motor that surely would be competitive with those running up to 1350cc motors. The elation was short lived when I realized this stroker kit would severely limit the RPM levels I could have run with the short stroke motor. Now I have to figure out all new gearing package to run the speeds I need.
« Last Edit: October 29, 2016, 12:37:23 PM by Powderman »
Offline grcamna2
« Reply #338 on: October 29, 2016, 02:05:01 PM »
OK,Then are you still going to run it at Bonneville ? w/ a stroker kit like that you'll need to gear it Way up.  :) Will you build a streamliner type 'aero' fairing for it? That's set-up Caf'e so it could get wobbly at speed
I thought it was a standard XLCH,didn't know what you had;I well remember as a kid how the XLCH Harley Sportster's would sound when they passed a car back in the late 60's,they had all kinds of 'spin'.
« Last Edit: October 29, 2016, 02:08:47 PM by grcamna2 »
Offline Powderman
« Reply #339 on: October 29, 2016, 02:24:35 PM »
I already have an Airtech full XRTT fairing made from mold from Cal Rayburn's XRTT bike. I'll first take it to the ECTA Ohio Mile and attempt the record there. It stands at just 131mph. If I accomplish that and find that the bike is stable at those speeds then I will consider going to the Salt. The salt has been very unforgiving the last 3 years raining us out of 5 of the last 6 events and the last one they ran the salt was so bad our car was loaded and on it's way home after just one pass and spinning out at over 225mph. The record for my class at Bonneville is over 173mph. I'm not sure right now at 63 years old that I'm ready to be dragging my ass across the salt flats at 175mph.
I have this fairing. The Emgo fairing will be run when I ride it on the street.
The dual carb heads and the pipes on the wrong side should have been a dead giveaway that it's far from a standard Sportster.
With the aerodynamics and the power to weight ratio I think the mile record is well within reach for me.
I'll be going for the fuel record because the gas record is already at 149mph. Why that rider didn't bump up into the fuel class and take that record also is a mystery to me. I can run gas in the fuel class, but not fuel in the gas class.
« Last Edit: October 29, 2016, 02:28:24 PM by Powderman »
Offline grcamna2
« Reply #340 on: October 29, 2016, 03:10:29 PM »
I don't know much about the Harley's;that bike of yours sure does sit low which is good.The heads/carbs. on it,are they similar to the XR750 style ? I hope when you do Bonneville that the salt is good and dried-out.  ;)
« Last Edit: October 29, 2016, 03:12:25 PM by grcamna2 »
Offline Powderman
« Reply #341 on: October 29, 2016, 03:13:41 PM »
I don't know much about the Harley's;that bike of yours sure does sit low which is good.I hope when you do Bonneville that the salt is good and dried-out.  ;)
Actually it sits at close to stock ride height. Low bars and the seat and tank make it look low. The heads are Sputhe heads made in the mid 70's. XR style, but bolt on to the XL Sportsters.
« Last Edit: November 04, 2016, 10:06:28 PM by Powderman »
Offline Powderman
« Reply #342 on: November 04, 2016, 10:24:13 PM »
Sold some parts off a CRX i'm parting out and put some more money in the Triumph kitty. Ordered the battery, exhaust pipes and clamps, brake fittings, carb spacers, clutch cable adjuster, and extended ticklers. Need a chain, choke cables and the GPS speedo and should be near completion. In the process of trying to install the wiring harness and hook everything to it.
Offline jag767
« Reply #343 on: November 05, 2016, 04:43:34 AM »
That's some harley! Light, lean, and mean, should really run strong!
Offline Powderman
« Reply #344 on: November 07, 2016, 10:51:45 AM »
Pipes came in and fit like a glove. Ordered the correct muffler clamps, but they sent me large coil clamps instead. They want me to return them for exchange. This is one case where I say you are responsible for return shipping as it was your mistake. If they don't correct the issue at no expense to me then they get  negative feedback.
I notice the left pipe has a more straight section going down than the right side that looks more radiused, is this just normal of 650 pipes?
Offline edwardmorris
  • Youngish
« Reply #345 on: November 07, 2016, 11:07:53 AM »
Totally digging the look! Can you please post a pic from the front, looking at both pipes and the engine. I know it might be tricky with the wheel getting in the way, but please try :)
Offline Powderman
« Reply #346 on: November 07, 2016, 12:39:53 PM »
« Last Edit: November 07, 2016, 12:45:48 PM by Powderman »
ken65
« Reply #347 on: November 07, 2016, 02:17:11 PM »
On mine there the same and look more like the  header on the number 1 side.
Offline Powderman
« Reply #348 on: November 07, 2016, 03:09:12 PM »
I know I got what is in the picture, they are definitely not symmetrical:
Offline grcamna2
« Reply #349 on: November 07, 2016, 04:09:42 PM »
Looks nice w/ that exh. on there  8) the chrome pipes really 'pop' w/ the blacked-out engine in the background.
