Author Topic: 1970 Triumph Tiger 650  (Read 73652 times)
Offline Powderman
Re: 1970 Triumph Tiger 650
« Reply #225 on: August 27, 2016, 07:49:13 PM »
Carbs rebuilt with all new parts, powder coated and ready to mount.
Offline Powderman
« Reply #226 on: August 31, 2016, 04:49:08 PM »
« Last Edit: August 31, 2016, 04:54:24 PM by Powderman »
Offline 72 yellow
« Reply #227 on: August 31, 2016, 04:56:56 PM »
Looks sweeter every time you post new pics..Great job.
Offline Powderman
« Reply #228 on: August 31, 2016, 05:03:06 PM »
A little bit closer every day. I have to go grind a groove in my rocker shafts and then I can torque the head and get this back in the chassis.
ken65
« Reply #229 on: August 31, 2016, 05:19:04 PM »
I wasn't sure at 1st about the all black on the older motor having a shiny one myself, but  have to admit it looks sweet. Good job.
Offline MoMo
  • Ride like you're invisible
« Reply #230 on: August 31, 2016, 05:20:42 PM »
Big fan of the black too.  Impressive
Offline Powderman
« Reply #231 on: August 31, 2016, 05:22:45 PM »
Thanks everyone for positive comments.
« Reply #232 on: August 31, 2016, 07:09:58 PM »
Larry,
The all-black look is reminiscent of the early 80's Yamaha 'Midnight Specials'
Offline Powderman
« Reply #233 on: August 31, 2016, 07:18:22 PM »
Larry,
Even Triumph now is making an all black motor. Would it surprise you guys to know that at least the cases on this motor my brother did in black over 40 years ago. I've just take it a step further and blacked out everything in varying shades of black. I think the paint scheme and the rest of the bike are going to tie in nicely.
« Reply #234 on: August 31, 2016, 07:57:30 PM »
Larry,
Be careful where you park it at night,you don't want a parking lot incident.
« Reply #235 on: August 31, 2016, 11:30:35 PM »
Did carbs go through full baking after coating? If so, did slides move nicely..?
Offline Powderman
« Reply #236 on: September 02, 2016, 08:04:04 PM »
Yes they did, not 10 minutes at 400°, but 15 minutes at 375°. They slides move freely in the bores. I don't foresee any issues from the coating process. Anything less than a full cure could possibly see issues up the road with contact with fuel spillage. These castings got nowhere near deforming from that low heat.
« Reply #237 on: September 02, 2016, 11:35:31 PM »
Hey powderman, I got some kz650 powdercoated engine covers that have been discolored by fuel...think of anyway to polish it out?
Offline Powderman
« Reply #238 on: September 02, 2016, 11:45:32 PM »
If you can wet sand the discoloration out you can cut and buff just like if it were paint. After you do that and clean them thoroughly put them in your oven at 400°f for about 20-30 minutes. I suspect your parts were not fully cured if it's discoloring from fuel contact. Actually i would secure it in the oven after wet sanding and before cutting and buffing.
« Reply #239 on: September 02, 2016, 11:57:53 PM »
I will try it.  Thanks
Offline Powderman
« Reply #240 on: September 06, 2016, 09:25:02 PM »
Ready to go back in the frame.
Offline MoMo
« Reply #241 on: September 07, 2016, 02:57:28 AM »
good for you     8) :)
Offline edwardmorris
  • Youngish
« Reply #242 on: September 07, 2016, 09:57:34 AM »
Gorgeous looking motor, and totally digging the black. Carbs came out excellent!
Offline Powderman
« Reply #243 on: September 07, 2016, 10:19:46 AM »
Thanks, can't wait to get it back in the frame and making some more progress towards completion. Needs about $1k and I just don't have it right now.
« Reply #244 on: September 08, 2016, 06:36:24 AM »
Looks fantastic, Powderman. You are making me want a Triumph...
ken65
« Reply #245 on: September 08, 2016, 05:58:33 PM »
Very smart. Looks good.
Offline Powderman
« Reply #246 on: September 12, 2016, 10:50:17 PM »
Had this finned rocker box oil cooler in the box of parts and went to fit it to the rockers only to find it is for a pre unit 650 that doesn't have fins on the rocker box. Fins got in the way of it fitting up against the box. I had to chuck it up in the mill and machine the back side to fit the Bonny head, it ain't pretty on the back, but it can't be seen and I was of course going for function over form.
Offline Powderman
« Reply #247 on: September 18, 2016, 09:36:26 PM »
Details, details, it's all in the details.
My new grip was too short for the existing throttle tube, so I had to machine 3/8" off the tube. Also the tube being raw aluminum and the grip being transparent threw the color shade off from the other side so I had to powder coat it black to match.
Before:
After:
I couldn't find any spacers locally so I cranked up the bench top lathe and made the spacers to locate the caliper brackets on the lower legs. They are now ready to weld to the lower legs.
« Reply #248 on: September 19, 2016, 09:23:06 PM »
I hope the piece you are planning to weld is bigger than that..like a long piece, that goes to both bolts..maybe wider on the weld edge, to keep the heat and distortion from that mount area.
Offline Powderman
« Reply #249 on: September 20, 2016, 08:41:01 AM »
I have a source for excellent TIG welders that understand my need to not distort the tube from welding. I may have to go in with my hone afterwards, but I expect that and see it as no big deal.
The bracket should be substantial enough for the job. 5/16" by 3-1/2"
