Author Topic: Today's pickup 78 cb750f  (Read 4508 times)
Offline Sdsbassist
  • Gus, Austin, MN.
Re: Today's pickup 78 cb750f
« Reply #25 on: January 31, 2016, 10:47:41 AM »
I just have a very strong feeling that that grinding off of it would be a killer. If I went to the dmv they could tell me it's being confiscated or some thing. I suppose it's best to just shoot em an email and ask.
Sent from my SM-N900V using Tapatalk
Gus, Austin, MN.
Current Bike:  75 750F
Past bikes: 76 750K - "Iowa Blue",78 750K Craigslist find - "Black Beth;" 77 CB750K Basketcase, with a 75K engine; 1970 Cb750 K1, "Rosa Luxembourg"
74 cb750, 75 cb550, 77 kawa 650, 81 virago 750, 83 virago 920, 80 Honda Twinstar 200, 71 Honda CT70, 1971 Honda CB750 Rat Project "Black Dahlia Bitsa"
« Reply #26 on: January 31, 2016, 01:32:47 PM »
 I think to have that tag it had gone thru reregistration.. call DMV see if they have a history of that having happened. meanwhile look for a legal frame.
 the motor.. to me it looks tampered with.. is that in fact true?  generally blank replacement cases are often not an issue..
Offline RevDoc
« Reply #27 on: January 31, 2016, 01:34:41 PM »
Gus, what were your intentions for the bike? Keep it for yourself or fix up and sell it? Either way you could go the Vermont route for a transferable registration and no title hassles. I have Vermont antique plates on both my bikes ($10.00/yr) ;D and have never had a problem with cops right behind me at lights.
If you wanted to sell the bike you just explain to the potential buyer about the antique (25 or older)/no title process for Vermont and transfer the reg. to the buyer.
Dana
'78 CB550K--Angie
'82 CB750 Custom--Eva
As soon as you straddle a bike expect every other driver on the road to suddenly start competeing for the title "Dumbestsonofa#$%*inallNorthAmerica!!"
Offline CB750F2
  • Pat's first Honda 750 F2
« Reply #28 on: January 31, 2016, 01:35:26 PM »
I would do the 3000 mile tune up as described in the service manual, then ride it to ensure that the transmission is OK. If all is OK then look for a used set of crankcases - they are on ebay. Pat
Regards
Pat from Australia
Offline CB750F2
« Reply #29 on: January 31, 2016, 01:38:39 PM »
Frank, the OP said that the engine number was ground off as if to say that the number was tampered with. Pat
Regards
Pat from Australia
Offline Garage_guy_chris
« Reply #30 on: January 31, 2016, 01:53:29 PM »
If it was me. Worst case scenario:
Frame:  you have to find a replacement frame with a good VIN,
Engine: I would mask off the vin area and coarse sandblast it to make it appear fresh and un stamped like the replacement cases from honda came. Then they can just be "replacement cases". or if you want it to be legit, replace the engine cases, but this is much more involved
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #31 on: January 31, 2016, 02:19:14 PM »
Yep probably parting this out.
Cases are definitely not blank, it's been ground, guessing at same time minnesota tag was put on. Anyone ever done a carfax or other related report? Wonder what it would say
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #32 on: January 31, 2016, 02:20:14 PM »
With the Minnesota stamp on there, I think we are good. Guessing it was stolen at some pt. And some a hole ground the numbers off frame and case. If I can find a decent motor it would be a matter or swapping out motors.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #33 on: January 31, 2016, 02:52:36 PM »
Here's my plan. Tonight a lengthy and descriptive email to DMV agent with pictures. Just be forthright and honest and maybe they will have an answer. Based on what they say I can make some choices. The guy I bought it from this morning said he didn't think they needed the engine number so it hadn't occurred to him. He did say he would buy the motor back if it didn't work out. Guess I'm only 300 into it but I was excited for the winter project
Gus, Austin, MN.
« Reply #34 on: January 31, 2016, 03:13:57 PM »
But it has a "recovered" tag Pat, looks like the frame number was ground off too, that bike has been re registered after being stolen and recovered, if that's all still all on file it shouldn't be a problem to register it again.... That frame tag should be proof enough... ;)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #35 on: January 31, 2016, 03:17:11 PM »
This is what I'm crossing my fingers for.
Gus, Austin, MN.
« Reply #36 on: January 31, 2016, 03:22:22 PM »
Hopefully, I've done this in Australia before, even had new numbers approved by the police and restamped... ;)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #37 on: January 31, 2016, 03:37:58 PM »
That's cool.. but sounds like a pain!
Gus, Austin, MN.
« Reply #38 on: January 31, 2016, 03:42:44 PM »
Yours shouldn't have that problem, its already been re registered.... ;)
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #39 on: January 31, 2016, 03:50:46 PM »
Like I said, fingers crossed.
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #40 on: January 31, 2016, 04:10:33 PM »
Here is my letter to the DMV Agent:
Hello!
I am a Minnesota resident and I am exploring the possibility of restoring a 45 year old motorcycle. It is a 1970 Honda CB750. The motorcycle I am looking at is mostly complete, but needs some repair. Also, there were a couple of questions I have about the VIN and engine number. I want to make sure that I do this right and correctly, hence the email to you today.
To the best of my knowledge, the bike was in the hands of a collector and off the road since 1987. At one point, it appears that the bike was stolen and recovered. There is a special red State of Minnesota Recovery VIN on the neck of the bike (attached in photos) where the VIN was ground off by what I assume was a thief. At that time the engine serial number was also ground off. (see photos)
I am looking to attempt to title the bike using a bill of sale from the previous owner, and a statement of facts. The thing that concerns me is that when doing a Statement of Facts (and a later title transfer), I would have to include the engine number on the form. Since the numbers were ground off prior to recovery, there are no numbers there.
My question is: Is this a project I should take on, or would the titling process be too complicated due to the uniqueness of the circumstances? What I know about the motorcycle are posted below.
I appreciate any help or assistance you may be able to provide.
VIN: CB750106XXXX
Last known Plate number: MM 60-
Last time tabs were renewed: 1987
Gus, Austin, MN.
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #41 on: February 01, 2016, 03:49:48 PM »
Sent email and called local DMV. they said no problem. Just put it on the form and it should be good!
Gus, Austin, MN.
Online Stev-o
« Reply #42 on: February 01, 2016, 03:55:52 PM »
Good for you!
Offline Sdsbassist
  • Gus, Austin, MN.
« Reply #43 on: February 01, 2016, 03:57:01 PM »
It's good to have the girl out there. And a K1!!!! Never had one before
Gus, Austin, MN.
« Reply #44 on: February 02, 2016, 03:48:03 AM »
Great score, congrats!
