Author Topic: Cam Tower Studs - how tight to seat  (Read 1271 times)
Offline Wingnut74
« on: February 06, 2016, 02:11:38 PM »
74 CB750k4.  i'm about to put the cam tower studs in and I cannot recall what I was told on how tightly to seat the cam tower studs into the head. Nuts were 70" lbs i think. And since those open up to the to the outside what kind of thread sealant is recommended. thanks
74 CB360 - Winter 2014/2015 Project
74 CB750 - Winter 2015/2016 Project
70 Something TBD - Winter 2016/2017 Project
Offline edwardmorris
  • Youngish
Re: Cam Tower Studs - how tight to seat
« Reply #1 on: February 06, 2016, 02:40:05 PM »
The studs have different length threads, I forget exactly but I believe the longer threaded end goes on top. The other end goes into the head and you just seat it snug. If you do not use a high temp thread sealant, its almost guaranteed to leak. Permatex's High Temp thread sealer works well. If you haven't already, review this thread again to make sure nothing was missed/overlooked.
http://forums.sohc4.net/index.php?topic=107040.0
« Reply #2 on: February 06, 2016, 04:26:44 PM »
I used ARP thread sealant, and no leaks.
I think I set mine in at 8ftlbs.
Offline koendd
« Reply #3 on: February 07, 2016, 02:01:46 AM »
I've used hylomar, worked good, no leaks.
Latest rebuild I've used permatex, haven't run it yet so wouldn't know but seems to be up to the job...
1972 cb750K2 brat
1976 cb360
1984 GPZ900R
