Author Topic: Anyone have a CAD file (or dimensions) of the CB350F Bar Risers Bolt Pattern?  (Read 947 times)
Offline sbeckman7
  • Glutton For Punishment And/Or
  • Slow and steady
I will be purchasing a Cognito Motorsport top triple for my CB350F but I want to retain bars using the OEM bar clamp/light panel.  For this reason I need to supply Cognito with the bolt patter of the clamp itself, and since a few forum members here have mentioned they have CAD models etc. I was hoping someone might be able to send me one?  Or just the bolt pattern if you know it  ;D
Spence
Offline sbeckman7
  • Slow and steady
Was I dreaming when I thought people had this info?
Or measure it with a metric tape, ruler or caliper..
 It will be nominal, and stick a handlebar in to measure offset.
 You may want to change bar offset if you would like to he able to slide your forks up..
Offline sbeckman7
  • Slow and steady
Alright, hopefully they won't have a problem with that. I don't see why they would
Offline sbeckman7
  • Slow and steady
He won't. Tell him I said to do it that way if he gives you any grief. He's a very good buddy of mine, and an absolute top notch guy!
FYI - Almost all bar clamps use pretty similar spacing on bikes of this model. They may be off slightly here or there. But you could essentially have a "lower riser" milled to receive the upper, then it uses a single stud to pass through the upper tree with a single hole, bolted from below. This would be less expensive for you (less milling, less material) and far easier to locate the bar clamps exactly where you want.
You're essentially making a "riser" that is drilled for your stock bar clamp, right? Depending upon the style of top tree you have made, you need to verify tank clearance, and gauge fitment. With a separate bar riser/clamp, you can position the bars slightly more forward to clear the tank, create visibility to your gauges, etc... If everything but the top tree is stock, then its pretty simple really to replicate with a new billet tree. But be mindful about where the forks pinch, and the clearance on the tank from the underside of the top tree. Billet will be much thicker, and you don't want to rub your tank  :)
Ha! Ok glad to know a guy who knows a guy  ;D  Thinking about giving my stock triple a weld-repair and seeing how it holds up with these mysterious D-washers that I have yet to source (or even see for that matter!).
Many custom trees simply have 2 holes for bar mounts.. Often 3.5 inch apart . You can use the cb350 and 450 risers.. Think the light bar clamp will work with them .. In that case measure the long distance between bolts and get him to drill that pattern
