Author Topic: CB750F1 pistons interchangeable?  (Read 914 times)
Offline Skoti
« on: February 16, 2016, 12:10:09 AM »
Hi,
technical question for experts.
Can the later type CB750F1 pistons, part number 13101 392 020 be fitted to earlier engines that are equipped as standard with piston part number 13101 392 000?
The earlier pistons have valve pockets on the piston crown and use different piston rings than the later pistons.
The later pistons don't have valve pockets and use different piston rings from the earlier pistons
According to the parts catalogue the valve gear and camshafts are the same on both models.
My 1976 CB750F1 has engine number 2544731.
Hope someone out there can help.
Best regards
Skoti.
Motorcycling is life, anything B4 or after is just waiting.
Honda CB750F1 1976
BMW R1150RT 2002
Norton Commando 850 Roadster 1974
Jawa 350 Blue Style 1992
Offline Skoti
Re: CB750F1 pistons interchangeable?
« Reply #1 on: February 17, 2016, 07:40:30 AM »
bump!
Honda CB750F1 1976
BMW R1150RT 2002
« Reply #2 on: February 17, 2016, 09:40:51 AM »
A ty písty máš?  Že bys to zkusil složit?  Taky můžeš zkusit napsat Hondamanovi:
http://forums.sohc4.net/index.php?action=profile;u=2043
ten by to moh vědět.
