Author Topic: Measuring o'ring 750 K1  (Read 1496 times)
Offline Guido56
« on: February 28, 2016, 11:51:44 AM »
Hello guys
I need help
Do you know the measures of oring of valves Oil of 750K1 head?
On the part list 3,7x1,7mm they say but what I took away was very different, more 'big.
Do you know the extent of the o-ring of the valve caps?
I tried on the part list but I can not find anything for sure.
Sorry for language mistakes but I'm using the Google translator
Thank you
Guido
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
Offline wowbagger
  • Not much of an
Re: Measuring o'ring 750 K1
« Reply #1 on: February 28, 2016, 04:36:38 PM »
Do you mean the tappet cover o-ring? If so, it's a 30.8mm o-ring. See part #13: http://www.cmsnl.com/honda-cb750k1-four-1970-1971-usa_model14354/partslist/E01.html#results
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: February 28, 2016, 04:43:12 PM »
It sounds like he's asking about the o-rings that go above the oil control orifices.  Those are listed as 3.7mm x 1.7mm.  Part Number 91317-300-003.
Guido, what motor do you have?  The parts book says that starting at engine # 22200001 this o-ring changed to 5.8mm x 1.9mm, part number 91305-323-000.
mystic_1
- John Augustus Shedd
Offline BPellerine
« Reply #3 on: February 28, 2016, 06:05:24 PM »
mystic_1
he says k1,so smaller for oil orfice
1978 CB 750K ard and webers
another anfob
Offline mystic_1
  • 1970 CB750K
« Reply #4 on: February 28, 2016, 06:30:40 PM »
Right, but he says he found something larger than that.  Always possible the motor was swapped.
mystic_1
Offline Guido56
« Reply #5 on: February 29, 2016, 01:11:02 AM »
Thank you guys
The number of motor and '11039..
The valve and 'this
Tis is the head
The bike It is this
« Last Edit: February 29, 2016, 03:06:19 AM by Guido56 »
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
Offline mystic_1
  • 1970 CB750K
« Reply #6 on: February 29, 2016, 03:55:37 AM »
Oh wow, never seen anything like that, either in person or in the parts books.
Sorry, I'm stumped.
mystic_1
« Reply #7 on: February 29, 2016, 05:01:09 AM »
Must be some regional aftermarket.  Even my K0 head had a normal - old style - oil jet.
Thank you guys
The valve and 'this
Tis is the head
The bike It is this
Offline BPellerine
« Reply #8 on: February 29, 2016, 10:45:01 AM »
that is a ko oil jet,the ones before that were just drilled and not removable,I have the same oil jets,later ones are the ones that look like an emulsion tube,my gasket set did not have the smaller orings so got some 4 by 2 mm as per hondaman,they sit around the orfice but do not cover the outer edge of the jet housing.billp
another anfob
Offline Guido56
« Reply #9 on: February 29, 2016, 02:17:28 PM »
The problem 'that I can not know the extent of the oring.
I can not find it on any part list.
Do you know the measure?
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
Offline BPellerine
« Reply #10 on: February 29, 2016, 07:01:36 PM »
think the originals are 3.7 by???,hondaman says you can use 4mm by 2mm orings you can buy them at auto shops,.bill
another anfob
Offline Guido56
« Reply #11 on: March 01, 2016, 12:53:56 AM »
Thank you guys
Try 'with a 4x2mm and maybe even a 5x2mm
Honda four 750 K1
Kawasaki Z1300 A3
Benelli TNT1130
